Solar Powered Auto Fan only $19.99 (+ shipping)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by timtim2008, Aug 9, 2010.
  1. 10priusII
    10priusII Junior Member
    22
    stockton
    Solar fan ....interesting!!
  2. ProfPlum
    ProfPlum Junior Member
    28
    Nevada
    I
    The other drawback that nobody has mentioned is that, unless you remove it every time you drive somewhere, you get extra wind noise, especially at highway speed.
    It's also a hassle to install, as you have to close the window with just enough pressure to hold the unit in place, but not so much that you distort the thin plastic case to the point where the fan won't even turn. Probably easy with a hand-cranked window, but almost impossible with an electric window.
  3. Lottamoxie
    Lottamoxie Member
    434
    63
    Southeast US
    One of those whole house fans (like what is in my house's attic) would work really, really well in a Prius, as far as moving the air out. But I suspect it would look pretty silly on the roof of a car.
  4. Michaelvickdog123
    Michaelvickdog123 New Member
    332
    US
    But you get the idea that removing, or displacing hot air in the cabin of the car (or attic of the house), helps keep temps down in the car (or house).
    Same laws of thermodynamics apply in both case.
  5. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    You just mount that fan on the roof in place of the sunroof, and when you drive off hit a button that pivots it up and then you have air power assist like an airboat!
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's a well-written paper but isn't consistent with my own real world experience. If I park my car for a few hours in the valley, I always return to a significantly hotter interior if the windows are clamped shut versus cracked opened all the way around.
  7. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    I even saw it selling for $14.99 @ Walmart. But it's still the more expensive of the 2 comparing with the Prius' solar panel, cause its usefullness is 0, and $anything/0 = infinitely expensive. Now if you rank its usefullyness as -1 'cause it lets in rain, do your own math:D
