Solar Roof Info for 2023 Prius Prime
Discussion in 'Gen 5 Prius Main Forum' started by drash, Mar 28, 2023.
  1. Tideland Prius
    16,556
    That’s correct.
    Maxwell61 and Gokhan like this.
  2. Maxwell61
    Maxwell61 Active Member
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    I'm wondering if someone has been able to intercept in DC-DC converter i guess, or what, the connectors of the cables from the solar roof to insert a connection to external FV panel.
  3. Maxwell61
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    Gokhan and Tideland Prius like this.
  4. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Not sure what disappeared but here's some interesting formation. I checked out the spec sheet for the 2023 Prius Prime:
    spec sheet: https://toyota-cms-media.s3.amazonaws.com/wp-content/uploads/2022/11/2023-Prius-Prime-Product-Information_03302023.pdf
    Battery Weight (lb.)
    284 (287 with solar roof – XSE Premium grade only)
    128.8 kg (130.2 kg with the solar roof)
    Just begs the question, are they adding a buffer battery within the traction battery?
    Spec sheet also shows a 3.5 kW charger built into the car.
    For reference the original Plug-in Prius (PiP) battery weight was 180 lbs (80 kg). 2017-2022 Prius Prime battery weight was 265 lbs (120.2 kg). So the 2023 13.6 kWh battery weight grew by 19 lbs (8.6 kg) over the 2017-2022 8.8 kWh battery.
    mountaineer and Gokhan like this.
  5. bisco
    51,910
    maxwell is saying the buffer battery disappeared, i think he's correct
    Tideland Prius likes this.
  6. Gokhan
    Gokhan Senior Member
    6,197
    2,452
    Paramount CA
    I would think that the number of cells is the same. 3 lb must be extra wiring and connectors on the battery to hook up with the solar roof.
    This could make it very hard to find the special battery with the solar-roof option fifteen years from now.
  7. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Looking at the cutaway again, it might be whole or part of the dc/dc converter that needs cooling, since the traction battery is liquid cooled. You have to convert the solar panel output to the same as the traction battery and buffer it to keep voltage swings from varying too wide. This could be clouds passing by or driving under bridges, tree branches, etc.. Now by buffer, it may not necessarily be a battery. Most dc/dc converters have voltage conditioners and are pretty much capacitor based.
    gggGary and Gokhan like this.
  8. Gokhan
    6,197
    2,452
    Paramount CA
    I think the solar-roof-equipped XSE Premiums will be unicorns. So far, there is apparently none in the inventory.
  9. bisco
    51,910
    is the traction battery liquid cooled?
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Yes
  11. bisco
    51,910
    Any details?
  12. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
  13. vallesj
    vallesj Junior Member
    98
    Based on GOOGLE BARD'S calculation answers, it's not worth te extra cost:
    The 2023 Prius Prime has a 18.1 kWh battery pack. The solar panels can provide up to 2.5 miles of additional range per day, which is about 6.25% of the battery's capacity. Therefore, it would take about 28 days for the solar panels to fully charge the battery on a sunny day.
    However, it is important to note that the solar panels will not always be able to provide the full 2.5 miles of range. The amount of power that the solar panels can generate depends on the amount of sunlight that is available. In cloudy or overcast conditions, the solar panels will not be able to generate as much power.
    The solar panels are also not able to generate power at night. Therefore, the 2.5 miles of range that they provide is only available during the day.
  14. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    The 2023 Prius Prime has a 13.6 kWh battery of which 11.5 kWh is used. Use the 11.5 kWh to make your calculation for the ideal 185W washed panel. ;)
  15. vallesj
    98
    You know bard and chatgpt-bing lie several times, so let me correct it, so it can improve. ;)
    drash and bisco like this.
  16. vallesj
    98
    Bard reduced it to 12 days.....
    "The 2023 Prius Prime has a 13.6 kWh battery pack, but it only uses 11.5 kWh of that capacity. The remaining 2.1 kWh is reserved for the car's hybrid system. This means that the solar panels can provide up to 2.1 miles of additional range per day, which is about 17% of the battery's capacity. Therefore, it would take about 12 days for the solar panels to fully charge the battery on a sunny day.
    However, it is important to note that the solar panels will not always be able to provide the full 2.1 miles of range. The amount of power that the solar panels can generate depends on the amount of sunlight that is available. In cloudy or overcast conditions, the solar panels will not be able to generate as much power."
    drash likes this.
  17. Maxwell61
    392
    241
    Italy
    2024 Prius Prime
    XSE Premium
    The NiMh buffer battery disappearance is deducted from the screenshot of the gen 4 & gen5 I've uploaded.
    Yes, I think it's a fair assumption that they added the buffer using an extra portion of the HV big battery, hence the heavier weight.[/QUOTE]
  18. bisco
    51,910
    the solar panel being 'worth it' is based more on the 'cool' factor than return on investment.
    all things being equal, i would pay an extra $600. for it.
    gggGary, Tideland Prius and drash like this.
  19. Tideland Prius
    16,556
    Yeah it’s definitely a cool factor and I suppose if you can take advantage of it, at least say you’re powering some of your miles by solar.
    Plus, you’re helping R&D for future Primes with solar roofs (e.g. RAV4 Prime with a larger roof)
    gggGary likes this.
  20. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    If gen4 had a 8.8 kWh battery and 6.6 were usable, the usable portion of gen 5 is probably more around 10 kWh
