Solar Roof Info for 2023 Prius Prime
Discussion in 'Gen 5 Prius Main Forum' started by drash, Mar 28, 2023.
  1. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    I think, the usable battery is actually 9 kWh, because 1/3 of the battery !should! be reserved for hybrid mode. At least that is RAV4 PHV usage, and new Prius should operate in the same fashion.
    It seems I love to use the word "should" :-D
    gggGary likes this.
    51,910
    new battery technology may mean that you cannot extrapolate gen5 stats from gen4.
    drash likes this.
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Getting wide variations on net kWh of the battery. At the 14:28 mark of Kirk Kreifels Prius Prime review he has an estimate of 11.5 kWh net.
    From Car and Driver
    2023 Toyota Prius Prime: Catching Up to the Joneses
    "Toyota also addressed range concerns by growing the Prime's usable lithium-ion-battery capacity from a C/D-estimated 6.2 kWh to 10.9 kWh."
    Toyota tweaks their batteries as they mature. Pretty sure comparing an air-cooled battery like the 2017-2022 Prius Prime to the lighter (per kWh), more compact liquid cooled battery in the 2023 Prime will not yield the same buffer. With the liquid cooling, Toyota will use more of the battery, and leave the same amount as what the 2023 Prius HEV battery at is sized which is 906 Wh (per Toyota Spec sheet) when the Prime reverts to hybrid mode. I would hesitate to speculate they would lop off 2.6 kWh at the top end.
    Trollbait and Tideland Prius like this.
  4. Gokhan
    Gokhan Senior Member
    6,197
    2,452
    Paramount CA
    In Gen 4, 6.30 kWh is useable. I verified it many times with ChargePoint Level 2 public EVSEs.
    From the BEV range/mpge numbers, In Gen 5, about 11.5–11.7 kWh is useable. We can find the exact number using ChargePoint Level 2 public EVSEs, but it requires dozens of measurements to average.
    The EPA formula for the BEV range/mpge is as follows:
    Useable BEV battery capacity (kWh) = 33.705 × BEV range (mi) / mpge
    Gen 4: 33.705 × 25 / 133 = 6.3 kWh
    Gen 5 SE: 33.705 × 44 / 127 = 11.7 kWh (with uncertainty due to two significant figures in the BEV range)
    Gen 5 XSE/XSE Premium: 33.705 × 39 / 114 = 11.5 kWh (with uncertainty due to two significant figures in the BEV range)
    #64 Gokhan, Apr 9, 2023
  5. wstt
    wstt Member
    147
    24
    I think the solar roof is a gimmick. Just for the cool factor. I’ve got a 2023 XSE w/ solar roof and I question if it even is working. Seeing this thread I think told me why. I live in Hawaii so basically right under the sun, and optimal charging conditions… but reading here it says the solar shuts off if the car get hot. Well Hawaii is hot and the sun is closest, and hot.
    I was shipping my car inter island so it sat outside for several days with the shipper. The range barely went up. Maybe 3 or 4 miles over 5 days. This was when the car was new to me so I didn’t know how to look up all the info. I plan on doing a test in the middle of a clear sunny day, with the sun directly overhead, for 2 hours to see how many kW or I should say Watts are generated. So far I’m 100% disappointed with the solar roof.
    hill and Gokhan like this.
  6. Gokhan
    6,197
    2,452
    Paramount CA
    Don't look at the range. Look at the SOC. It should be a lot more than that in five days.
  7. JPI
    JPI New Member
    Arizona
    2023 Prius Prime
    Any assistance on helping locate one with a solar roof? I used the inventory feature but it's only for new vehicles and slim pickings.
  8. Gokhan
    6,197
    2,452
    Paramount CA
    If you contact a dealer, they will locate and get a new one for you.
  9. otatrant
    otatrant Active Member
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    Alternatively Truecar.com and cars.com allow you to search new car listings. If you are willing drive 500+ miles you can enter zip codes for different areas into truecar.com and set the distance you would be willing to travel to see listings. With the listings from truecar.com you can then find the Toyota dealers and look at their new car inventory page. The one catch is that to use the service for truecar.com you have to provide a phone number. I used a google voice number to avoid the hassle of getting contacted every time I wanted to see the sticker.
  10. JPI
    JPI New Member
    Arizona
    2023 Prius Prime
    The local dealer checked the site and inventory and none were available
    I have been using those along with Auto trader but honestly thier filters are trash. They can't even distinguish between models properly. I can wait but not going to wait 6 months just for this feature. Believe I ran out of sites to check
    #70 JPI, Oct 20, 2025
  11. otatrant
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    I noticed TrueCar didn't have a option for selecting solar roof when I did a quick search. I did find my Prius Prime using Truecar in addition to searching google maps for Toyota dealers then going to their sites. In late 2023 someone made/released a google sheets document with all the Toyota inventory for the USA/Canada and it made finding my bother-in laws Toyota Sequoia a lot easier. Unfortunately the document has been take down the last time I checked.
    I was curious what ChatGPT would have to say. Had a couple of ideas that where new to me. Here are a couple of sites I never heard of.
    ChatGPT also mention using options codes in searches. Doing a quick didn't turn up anything for the solar roof but it may be worth pursuing.
    ChatGPT also suggests saving searches and enabling email/text alerts at the various sites.
    Good Luck!
  12. Gokhan
    6,197
    2,452
    Paramount CA
    Your dealer guy has no idea what he is doing. There are currently 11 in stock in the Texas area. You can have one shipped to your dealer. Or you can fly there and drive it home.
    Moreover, the dealer inventory shows a lot more than what the public inventory shows, including future, planned production. So, they didn’t even bother to look.
    Toyota inventory | Solar roof | Texas area | New-Toyota inventory search
    otatrant likes this.
  13. hill
    8,804
    Bad idea in some states that you might fly in from. For example we have no automotive sales tax & if you buy in person, Texas will tack its 6¼% sales tax. Then if you have a car shipped, they'll get you that way. Plus wfatever mileage you rack up driving to your home destination. So you have to figure out which way costs you less.
    Gokhan likes this.
  14. otatrant
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    I read a while back that you pay sales tax on a new car depending on where it is going to be registered. Here is a link to a site that states the same is true with an out of state car purchase.
