Solar roof missing in action
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Feb 24, 2024.
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Currently, there seem to be no Prius Primes with a solar roof in the inventory. I doubt more than a dozen or so have been sold in the USA so far. Note that a solar roof is only offered as an option on the XSE Premium trim.
    Does anyone here have a solar roof? Why is Toyota not offering more Prius Primes with a solar roof?
  2. Trollbait
    12,832
    Maybe because gas is cheap here, so they save the solar parts for cars going to Japan and Europe.
  3. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Evidently, the solar roof is a port installed option. I suspect that it will make the car harder to sell if the seller cancels out after the modification is completed. It adds extra cost to the car (over $600) and has a payback of 50 cents or so per day.
    The solar option seems like a good option to have, especially if we ever have another oil embargo , shortage or power grid failure. Even if it only adds 3 or 4 miles per day to the Prime's battery, that's enough to get you around town to run errands or to reach the nearest gas station. If you drive the car around town once every 3 days you will usually have a decent state of charge when you need it WITHOUT worrying about what the Power company is doing to your electrical supply.
  4. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    That 3 or 4 miles per day will only get me 1/2 way to town..........
    Girl__wonder likes this.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Because it's a bit of a silly idea. The amount of electricity from it is minuscule.
    daisy555 and RandyPete like this.
  6. Gokhan
    6,715
    2,672
    Paramount CA
    How can something as complicated as a solar-roof system can be a port-installed option? The cars with solar roofs don't even have the same PHEV battery as far as I remember. It also has other parts that go into the car.
    AndersOne and Mendel Leisk like this.
  7. Beach Dweller
    Beach Dweller Junior Member
    46
    28
    The Beach
    2024 Prius Prime
    XSE Premium
    If I could have found one, I would have bought it. I wanted the added power produced to run the AC as it is a necessity down here on the coast. Couldn’t find one.
    I also don’t think it’s a port installed option, rather comes from Toyota that way.
    Gokhan likes this.
  8. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    While that is quite possible, there are circumstances where it works. In my case, I only drive it every few days and typically less than 10 miles at a time. If I can add 4 miles of charge to the battery every day, then my weekly charge from the grid is likely to be nothing.
    ... And the bragging rights over the neighbor with a Model S Tesla and $15,000 solar installation is even better.
    Gokhan likes this.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Oh wow, to run A/C?!
    That's a bit like using a teaspoon to prevent the Titanic from sinking.
    RandyPete likes this.
  10. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I'll try to find the paperwork that I came across last week. It had the classification for each major option, and the solar roof was one that was marked as installed at the port.
    Beach Dweller likes this.
  11. phase
    phase Member
    106
    42
    Portland
    2023 Prius
    LE AWD-e
    is there a way to wire up an after market solar panel to charge the battery? obviously it wont look as clean and OEM but is it possible?
  12. Mendel Leisk
    42,361
  13. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    You could fill up your trunk with folding solar panels, but you'd need about 5 parking spaces.
    And someone would steal them.
  14. Beach Dweller
    46
    28
    The Beach
    2024 Prius Prime
    XSE Premium
    Heehee, when the temps are in the 90s, AND the humidity is 80-90%, AC becomes important. At least my wife thinks so! :cool:
    daisy555 likes this.
  15. AndersOne
    AndersOne Active Member
    346
    200
    Europe
    2023 Prius Prime
    The solar roof is obviously geared towards the top trim with all options. Given the Prius generally starts very affordable in the states, it seems the target group are mostly price-conscious buyers.
    In Europe they sell only the Prius Prime and even the lowest trim is pretty good (and more expensive than a Tesla Modely Y) while the highest trim (you need that e.g. for Softex and 360) automatically gets solar roof. So many people (including me) just take highest trim to get the best stuff and have the solar panels despite not needing them.
    Price-conscious buyers would never buy a prius here - or cant afford it in the first place.
  16. Gokhan
    6,715
    2,672
    Paramount CA
    Well, for beginners, the solar roof is not expensive. It is only $610. The reason why it is so cheap is that because you lose the standard fixed glass roof if you get the solar roof.
    However, again, you lose the standard fixed glass roof if the solar roof is there. I think that is one reason why Toyota is not keen on it, as the Gen 5 Prius has been all about styling.
    I think the other reason is because it requires a different PHEV battery pack, which complicates the supply. I don't know exactly what is different about it—perhaps there is an extra wire harness that plugs into it.
    Regarding port installation, this is impossible. You are talking about installing wire harnesses, an extra charger, a different battery pack, and precisely and cleanly gluing and sealing the solar panel on top of the car and drying it with a heat gun. Something like this can't be reliably done out of the factory and would also take several hours.
    As far as the added miles, it is 185 watts. So, if you park your car from 9 AM to 5 PM under the sun, you would get 1.48 kWh, which is 9 miles of city driving on my Gen 4 and probably about 7 miles of city driving on Gen 5. If your commuting distance is short, you could get away with not charging or fueling your Prius Prime XSE Premium with the solar roof at all. It is a pity that they don't put it as standard equipment instead of the fixed (nonopening) glass roof, the latter of which is only a styling feature without a functionality (other than seeing the sky if you look up instead of watching the road).
    #16 Gokhan, Feb 25, 2024
    Sarge and RandyPete like this.
  17. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Personally, I prefer the airiness/natural light of the glass roof over the small amount of energy the solar roof would generate. Not to mention, it is one more thing to consider when parking/charging, as you will not want to fully charge the battery when parking during the day and “waste” the solar energy, and always leave a bit of headroom for the solar... That considered (along with the lower cost), I prefer the glass roof. I just wish it opened. :confused:
    Of course, the solar roof is not even offered in Canada (since we get less sun in the north), so there was no decision for me to make anyway, lol.
    Gokhan likes this.
  18. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, you didn't get the solar roof, but you did get the yellow. (Still super jealous of that. lol)
    Sarge likes this.
  19. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If someone was selling a 3rd-party sunroof with a solar panel that actually opened,
    I'd buy it.
  20. Sarge
    Sarge Senior Member
    1,325
    785
    2023 Prius Prime
    XSE Premium
    lol, yeah…. It’s a trade-off I am willing to take. :cool: I still don’t understand Toyota’s decision not to offer it stateside… o_O It’s a sweet colour.(y)
