Solar Roof Question
Discussion in 'Gen 3 Prius Main Forum' started by NDTransplant, Mar 22, 2012.
  1. NDTransplant
    NDTransplant Junior Member
    26
    Arizona
    Considering buying a Prius to replace an aging '99 Honda Accord. I have a question about how the solar roof option operates.
    For example, living in AZ, when I park the our Honda outside, I have the sunroof closed, with the interior sliding panel closed to block out the sun.
    In order for the solar roof venting option to work, do you need to leave the sunroof glass open? How about the interior sliding piece that you would close to keep the sun's rays out? It seems like if you had to let the sun shine into your interior via the sunroof, the interior would become that much hotter due to direct sunlight.
    I haven't actually looked at a Prius with the solar roof option, so I admit I'm completely clueless to it's operation, functionality, and effectiveness.
    Thanks for your info.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    No you don't need to have the sun roof open. Once activated via a dash button, the operation is totally seamless. Electricity via the solar cells on the roof panel power the ventilation fan in the dash. The fan is a more heavy duty version than in the a non-solar equipped model and the air is pulled through a cabin air filter to keep dust to a minimum.
    It brings in outside air so there is no true "air conditioning" but the effect can be tremendous compared to regular car with the windows closed. We have a black honda civic and it's truly a night and day difference compared to it in the summer. An additional benefit is the remote a/c which is like an auto start in a regular car. It can turn on the a/c via the remote but the range of the remote is rather limited.
    A good analogy is its like having all your windows, not just the drivers, rolled down an inch or two but without the security or dust issues.
    I also recommend a quality windshield sun shade and tinted windows for the ultimate defense against El Sol.
    KCTheis likes this.
  3. Eoin
    Eoin Active Member
    593
    116
    Long Island
    I have the solar roof. You leave it closed on a hot day with the sliding shade closed. The solar panel is on the roof behind the moonroof and does not move. It supplies electricity to power a small fan in the car that keeps the car from becoming an oven. So the moonroof and solar panel are separate things though they do come in one package.
  4. NDTransplant
    26
    Arizona
    OK, thanks, guys. I think you two set a new world record for fastest response time to a noob's question.
    I did review a view other threads about solar roofs, but your explanation about how they are part of a package but operate independantly of one another clears it up for me!
    Thanks again!
  5. fotomoto
    5,639
    3,815
    So. Texas
    Solar roof panels make electricity for the fan inside the car. It does not charge the battery.
  6. fumbling
    fumbling Junior Member
    17
    irvine
    I noticed if you leave the sunroof in the open position, the sunroof blocks the solar panels and the fan doesn't come on to cool the car...although I guess the open sunroof helps heat escape?
  7. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    How much is the "solar roof" option pricing.......
  8. Gilbert
    Gilbert Member
    255
    1500 msrp
  9. WE0H
    WE0H Senior Member
    3,247
    528
    Invoice is $3418 for the Solar Roof package on a Four. That includes an upgraded Audio/Nav system, speakers and all :p
    Mike
  10. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I have the option and thought I would regret it, but it's great. I actually keep the roof in vent position and I like that option. I keep the inside panel mostly closed. I do admit that if I have a shady place to park, I still choose that over the sun...
  11. Tideland Prius
    16,670
    But that kind of defeats the purpose of the solar panel ventilation system, no? The idea that you can have the security of closed windows and still have a ventilated cabin.
  12. Normie1155
    Normie1155 New Member
    You would think that they could of used the solar roof to help keep the battery charged. The Prius already has a battery indicator displaying the amount of charge, take a feed of the battery indicator to regulate the charge to the battery. I don't understand why Toyota would build a solar panel just to run a fan?
  13. WE0H
    WE0H Senior Member
    3,247
    528
    I don't know either. What I am going to do when I finally get my car home, is to measure the solar panels maximum voltage and see what current potential it can put out. If it is high enough for use with my Amateur Radio equipment, then I will install a dedicated accessory jack to use when I am out operating portable and need to keep my small 12v battery topped off.
    Mike
    :madgrin:
  14. Tideland Prius
    16,670
    Or you could read this:
    https://techinfo.toyota.com/techInfoPortal/staticcontent/en/techinfo/html/prelogin/docs/3rdprius.pdf
    3.6A Max, 27V. (22V on an average sunny day)
    priusincc and WE0H like this.
  15. WE0H
    WE0H Senior Member
    3,247
    528
  16. Tideland Prius
    16,670
  17. KCTheis
    KCTheis New Member
    Gainesville, FL
    I'm a newb! This post was helpful. I'm wondering if you know any more about this feature....
    I just bought a 2010 Prius IV this past weekend. When I push the button to activate the solar powered cabin filter option an indicator light flashes in the info panel SO quickly I don't know if it actually turned on or if there is an issue? The indicator light is definitely red, and it looks like there is a lock symbol over top of it, but it happens so fast it's hard to tell.
    I can tell that there is a difference in the physical button itself after it's been depressed, but the lack of a lasting indicator light is confusing.
    Any thoughts on the matter would be appreciated!
  18. fotomoto
    5,639
    3,815
    So. Texas
    Once you activate the switch (yes it's confusing), it takes about 10minutes AFTER the car is powered off for the ventilation fan to begin running. And it has to be in strong sun of course.
    KCTheis likes this.
  19. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The flashing light you're seeing has nothing to do with the solar panel or sunroof.
    Your best bet is to leave the button depressed. Within 10 minutes of parking the car (if there's sufficient sun) the fan will be run off of the solar panel. If it's dim sun it might run for several seconds then stop, then run, etc.
    If you're planning on parking in a dust storm or downwind of a bonfire or something you might want it off. Mine stays on 12 months of the year (it won't blow below a certain indoors temperature).
    KCTheis likes this.
  20. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    If you are thinking of using the solar power to do -anything- be aware it uses a -noisy- switching regulator. Just a warning.
