Solar Roof Troubleshooting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Xjmyway, May 29, 2019.
  1. Xjmyway
    Xjmyway Junior Member
    22
    77
    San diego
    So I've had my solar roof (used purchase) for about 6 months now and it's been pretty cold most of the time. The weather is warming up and I can't seem to determine if the system is in fact working or now. The switch is pressed in always and never get's turned off (out position). I have released it and pressed it while the car is running also. The car has reached upwards of 70° or higher and in direct sunlight. I hear no signs of a fan running or feel anything in the car. I can't find any real "troubleshooting" info online anywhere. Does anybody know of common things to look for that would cause malfunction or something out of a service manual that explains any test procedures?
    Thanks in advance!
  2. 2014
    2014 Member
    30
    31
    MA
    New to a 2014 Prius with solar roof. The manual says to press the switch when the car is on. I did that and came back to the car and heard the fan running (passenger side at top of hood/bottom of windshield). Wasn't sure if you need to press the switch every time before you leave the car but I did not and I heard the fan running again when I returned to the car. Was a hot day, maybe 75-80. Not sure if the fan operation is temperature controlled, would make sense that it was. The inside of the car was slightly cooler, I think, than if the fan was not running.
  3. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Adding to the problem of troubleshooting is the fact that after you turn the car off with the switch in (which enables the system) it will take about 10 minutes or so before the fan runs for the first time. After that it will cycle on and off, lower and higher as enabled by the amount of sunlight and as needed based on the air temperature (inside and outside the car).
    fuzzy1 likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Mine comes on after 10 minutes of locking car with fob. And no need to press the AC button, that’s manually turning on the AC with the HV bat so that’s isolated to the solar panel. Doesn’t matter the in or outside temp, it’s just the sun’s angle and intensity of the rays that will provide power. Mine runs during winter even when it’s colder than 50F no matter thermostat temp set during mid days.
    Ed Beaty likes this.
  5. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    With the solar package the primary fan is a higher capacity and there is an extra fan. You can leave the button depressed all year long in warmer US states. Doesn't do anything in Minnesota winters. Once activated, in about 10 minutes or so on a warm day you can hear the fan(s) running at different speeds as Walterm stated previously.
  6. cww180
    cww180 Junior Member
    28
    34
    Virginia
    I can hear mine from outside of the car, if you find out what it is let me know I’m parting out my 2010 IV so I have some parts available.
    Xjmyway likes this.
