Solar Roof
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Man In Black, Jul 31, 2013.
  1. Man In Black
    Man In Black Junior Member
    I'm glad I found this forum, this is my 1st post. To start, I have a small vending machine company as a second job and I am planning on using a yet to be purchased Prius to deliver product, I've heard a little bit about the solar roof option which allows for interior cooling when I'm not in it which will be great for keeping some of my product from melting.
    My questions are these.
    1. How cool will the interior stay with this cooling option? I understand it depends on many factors, but generally speaking.
    2. I'm having trouble finding a suitable used Prius with the solar roof option, is it possible to get one without the solar roof now and have it installed later?
    Thank You
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It will not make it cooler than the outside ambient air, all it does is take air from the outside and bring it inside the car. Others who have it can chime in in how long it operates etc.
    Nah, it's not something you can just pop on like an accessory.
  3. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    It does draw in outside air and helps as lomg as the solar panel has sun to run it also you get the FOB with the A/C option on it so you can run the A/C for up to 4min before you enter the car. All this does help it is a expensive option but I do like mine............ I just saw one at my dealer NW IL 2012 but still NEW.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The solar feature keeps the interior of the vehicle from getting blazing hot by circulating in outside air. It's still going to be warm, but you won't feel like you just climbed into a blast furnace as with other vehicles. Having the glass on top that opens is really nice for keeping cooler while you drive too.
    As for having it installed later, not a chance. It's a well integrated design no aftermarket attempt could easily match.
  5. Man In Black
    So if I took it to a Toyota dealer they wouldn't be able to install it then? I'd have to find a used Prius with that option already installed from the factory?
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, it's not something that is simply installed after the fact even at a Toyota dealer so yes, you would have to find one that was produced with the solar roof option.
  7. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    I have the roof and love it for more than just the fact that the car doesn't get so hot under certain circumstances. By that I mean that the solar panel produces more juice at high noon than it does when the sun is low in the sky.
    I leave mine enabled year round, there is a switch to defeat it if you wish. It operates even in the winter here when the sun is out.
    Big benefit is that it dries out the hvac system on a daily basis, so never have I encountered any smells that would suggest mould is taking hold in the car. We get a lot of rain and humidity up here for much of the year.
    The other reason I bought is my intention to keep my Prius for the long run. With closed windows and roof when parked in the heat of summer, the air brought in by the vents is directed out of the car through a vent positioned by the back passenger wheel. It is forced to cool the traction battery by design that way. Since I believe heat can be bad for battery life, I tend to think that having the interior temps kept down during the strongest or highest temperatures in the day is going to help with my batteries being happy campers. Your little 12 volt battery lives in close proximity to the exhaust vent too.
    Finally, you cannot add this later, it is something you get with the car from the factory. Good luck finding one, I'm sure that you will in time.
    Roland
  8. xcuter
    xcuter Active Member
    303
    182
    For what your doing your better off just leaving the car on ready and have the a/c running. When a Prius is in the ready position a/c will be on and the engine will start only to charge the battery when needed. Only thing is in the ready position the car can be driven. Just make sure doors are locked and you have some type of steering wheel/brake locking device.
  9. MPGnutcase
    579
    114
    Chicago
  10. fuzzy1
    10,672
    I very much doubt that it will keep typical vending machine products (e.g. chocolate) from melting, though it should slow down the rate that it gets melted.
  11. MPGnutcase
    579
    114
    Chicago
    Dark Chocolate melts slower!! :love:
  12. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Maybe you can rent a Prius with a solar roof from the dealer for a day or two and test.
    Preferably on a hot summer day
  13. DaWeav
    DaWeav Junior Member
    91
    Lemoore, CA
    The solar roof works best for me when I park facing the east/west vice north/south with the windshield shade I bought in place. The added remote A/C option is only good for making the air immediately chilly when I get in and start the car so I don't have to wait for the cooler air to start coming out of the vents on a hot day.
    GT-P7310 ? HD
    JMD likes this.
  14. Eric Henley
    Eric Henley Junior Member
    60
    How does the perform in the winter... Does it generate warm air or does it just not function at all?
  15. MPGnutcase
    579
    114
    Chicago
    Well I have not had the car during the winter yet but it has to be over 70 in the cabin to turn on so no in the winter it would stay off
