Sold My 2024 Prime
Discussion in 'Gen 5 Prius Main Forum' started by Toyotaworker, Nov 1, 2025.
  1. Toyotaworker
    Toyotaworker New Member
    2024 Prius Prime
    So I traded in my 2024 Prime with 17K
    Why because I picked up a 2026 Plug In
    I absolutely love these cars. I was getting 98km’s on a full charge of pure electric power that’s a good jump from the 72km’s it’s rated for.
    A couple of things that have changed and I don’t know if it’s new for 2026 or if it happened on the 2025
    The Energy Flow graphics on the head unit changed and don’t look so cartoonish
    The EV/HV/Hold button is only EV/HV button now (meaning you used to be able to charge the EV battery) when you pushed and held the button would just use the ICE
    When you plug the cord into the car you used to hear the locking mechanism right away now “if the doors are already locked you’ll hear it” if they are open you will not but it still locks in the charger if you have it set on the setting to do so
    mountaineer and bisco like this.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If I'm still driving my car in 10 years, I'll be fascinated to know what kind of battery upgrades will be available.
    pod and PriusCamper like this.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    Ha, the car is being downgraded every year ever since Gen 4. It sucks that they have even got rid of the charge mode now.
    Templeton and Danno5060 like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,451
    5,430
    Pacific Northwest, USA
    Saltyhybrid.com is already doing R&D for when that time comes!
  5. bisco
    52,829
    toyota has never done battery upgrades
  6. Mendel Leisk
    42,331
    The 2024 was getting grubby dusty?
    #6 Mendel Leisk, Nov 3, 2025
    Danno5060 likes this.
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    If I can believe 1% of the hype, the batteries of 2035 will be much better than what we have today.
  8. Gokhan
    6,714
    2,661
    Paramount CA
    12-V battery, traction battery, mid-generation, generation?
  9. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Care to elaborate on this and convince me it's not user error/misunderstanding?
    It seems someone is spreading this uncritically, but I've seen no evidence of a change in any source (other than this quoted sentence).
    There are newly updated specs and manuals including the 0W8 oil change (which you didn't mention but probably applies to you), but they still describe charge mode.
  10. Gokhan
    6,714
    2,661
    Paramount CA
    It is no longer in the 2026 owner’s manual.
    msi1259 likes this.
  11. bisco
    52,829
    mid generation traction battery?
  12. Gokhan
    6,714
    2,661
    Paramount CA
    Were you asking about a mid-generation upgrade to the traction battery?
  13. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Okay, it appears that they may have removed charge mode only for American models.
    There are new manuals from 2025/07 for all regions, all of which newly specify 0W-8 oil.
    The US/Canada version is the only one that has had the charge mode sections removed.
    (I'd previously failed to find this on the US site, but it finally occurred to me to get it from Canada).
    Wonder what prompted that?
  14. bisco
    52,829
    yes, have they ever done that?
  15. bisco
    52,829
    charge mode removed? surprising
  16. Gokhan
    6,714
    2,661
    Paramount CA
    Toyota upgraded Gen 4 NiMH batteries to Li-ion batteries mid-generation for newer model years. If you wanted to do it yourself, you would probably have to upgrade at least the hybrid computer as well.
  17. Toyotaworker
    2024 Prius Prime
    Had no idea about the oil. I was only stating things different from my 2024.
    i think I was pretty clear about the EV/HV/Charge button
    yes not user error as I said not sure if it was 2025 or 2026 where it was no longer
  18. Toyotaworker
    2024 Prius Prime
    I’m in Canada. I went from a 2024 SE to a 2026 SE and it is no longer there, I previously would use it on the expressway when I had 0% . I believe the U.S. models don’t get heated front seats or steering wheels
  19. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Yeah, I was just doubting it because it was still there in the new specs and manuals I looked at, and no-one else had ever mentioned it until you.
    Turns out it's a North America-only removal. For some unknown reason.
    Your specced oil is 0W-8 now, so keep an eye out for that. Bit more expensive, I gather...
    I've never used Charge mode myself - apart from just a random fiddle - it's almost never the optimal solution.
    If you find yourself using it to get yourself back up from 0% on a long drive, it would have been better to switch to HV mode earlier to hold charge and not drop to 0% in the first place, rather than discharging and charging back up.
    But useful in the event of a miscalculation, when you've failed to do that, maybe.
  20. Trollbait
    12,822
    Gen4 had battery chemistry vary between trims since its introduction. Eco and higher trims always had Li-ion.
    Happen to try holding down the EV/HV button to see what would happen? If it doesn't work, my guess is swapping in a EV/HV/Hold button will return charge mode.
