Sold My 2024 Prime
Discussion in 'Gen 5 Prius Main Forum' started by Toyotaworker, Nov 1, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    That is what I was saying. The ones that originally had NiMH were upgraded to Li-ion later on.
  2. Trollbait
    12,831
    Which isn't an upgrade of the battery for the model. As was done for the Volt, Spark EV, and gen1 Prius.
  3. Mr.Vanvandenburg
    1,361
    663
    2020 Prius Prime
    I would be happy the charge button is simplified. I had to learn not to get into charge mode by holding button down too long. As it is in all black on the dash and low to the side, I find it hard to see the button unless I stare at the area for a second.
  4. Gokhan
    6,714
    2,672
    Paramount CA
    And why is that? A Li-on battery performs better than a NiMH battery, and it is lighter. It is not to mention that it is much more durable.
    As far as I know, all NiMH Gen 4 batteries were upgraded to Li-ion in later model years if that’s where you are mistaken.
  5. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    One possibility for charge mode being removed from US/CA Gen 5s could be how many owners here and possibly other Toyota forums bashed it so badly as utterly useless and worse.
    @john1701a did a few videos showing how Hybrid Assistant tracked the mode in action.
    I used DrPrius on an empty stretch of a Parkway and noticed a few interesting aspects of how charge mode works, myself.
    Especially between 20 and 55 mph. Then there are the differences between holding a steady speed on the " flat " compared to what the gauge shows during acceleration or deceleration. Spiking up from the Gen 4s average " steady speed on the flat speed of 20mph " charge rate of 20 Amps to 40 Amps for short periods.
    Then there are the hills and valleys behavior where the charge level bounces all around the Amp gauge continuously. :whistle:
    john1701a likes this.
