Sold the 2013, got a 2008 Prius!!!
Discussion in 'Gen 2 Prius Main Forum' started by PriusRay128, Jun 14, 2020.
  1. PriusRay128
    PriusRay128 Junior Member
    CALI
    Hello Everyone,
    I had a 2013 Prius 3 which i loved with 90k miles and got a offer i couldnt refuse and sold it. Many months later, I just bought a fully loaded 2008 Prius from one of my customers with a faulty Transmission to use for work. She had the Hybrid battery replaced last year at the Toyota dealer for $2,800 dollars as the car has 118k miles.
    I installed a used transmission with 74k miles off a 09 Prius, since i had it open I also replaced the inverter and regular water pumps, spark plugs, belt with oem toyota parts. Drives great, def a different drive than the generation 3. Only weird part is the bluetooth is only good for phone calls and cant play music from my smart phone????
    Data Daedalus and bisco like this.
  2. The Lizard King
    Data Daedalus, SFO and PriusRay128 like this.
    49,433
    are you a hybrid mech? can we refer people to you?
    SFO likes this.
  4. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    Welcome to our generation of Prii. 2008s were not equipped for playing Bluetooth music, only telephone calls.There is a 3.5mm jack located inside the console at the front that is for playing music from a phone or mp3 player.
  5. PriusRay128
    CALI
    I run a body shop and automotive repair shop. Honestly, i hardly get priuses come in since they hardly ever break down. Its usually the hybrid battery that fails when they come in but only 2 or 3 a year and most got 200+k miles!!! Best mechanically built cars IMO. If you ever need suggestions for parts, feel free to ask. The transmission ran me 315 dollars with documenting miles from a vehicle that was hit in the rear and and running condition!!!!
    bisco and SFO like this.
  6. PriusRay128
    CALI
    Awesome info. I was leaning towards that way instead of changing the head unit. Very weird Toyota went that route with their bluetooth haha
    srellim234 likes this.
  7. PriusRay128
    CALI
    Always been a risk taker, i take my chances. No risk no reward. You can find non oem cats for 150-200 dollars
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    You're happy with what you've got.
    You have some DIY skills that allow you to maintain, cheaper than someone with no skills.
    I would put any worries about Catalytic Converter theft in the Porcelain Throne with the magical whirlpool and flush.
    The theft does happen, it unfortunately seems to be growing, but IMO you don't live in fear.
    If you can replace the transmission, the inverter, and water pump?
    IF and only IF the catalytic converter would be stolen? My bet is you can find a way to fix it.
    But why worry about something that hasn't happened, and may never happen?
  9. T1 Terry
    T1 Terry Active Member
    608
    314
    What failed in the transmission and any idea why? I have a gen 2 2008 with big miles on it and besides having to change the cat, it runs like a train. I did change the timing chain, but that was a misdiagnosis on my part and the taxi mobs mechanic. I did replace the lead acid starter battery with 4 LFP cells I had from a very tired house battery pack that had been seriously abused and that sorted the failing 12v battery problem. It still goes flat if I forget to disconnect it if it is going to be parked up for more than a week, but it recharges every time and doesn't throw any of those failed battery codes.
    T1 Terry
  10. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    You have to remember that this generation was designed prior to and released in 2004 with an update of some features in 2006. This was 3 years and 1 year before the first smartphone (iPhone) was released in 2007. Bluetooth would have been in its infancy too.
    Montgomery likes this.
  11. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Not really. Back then streaming music wasn't part of the very first bluetooth capabilities. That would come a couple of years later for most autos. BTDT
    You can get a good yet cheap ($20) bluetooth adapter that plugs into the mini-jack in the armrest and use AUX for music streaming.
  12. Mendel Leisk
    38,705
    Our 2010 doesn't have Bluetooth for music, just phone calls.
  13. Rose02218
    Rose02218 New Member
    Ukraine
    1999 Prius
    I think this car has a place to be. I adored my Prius until I had to say goodbye to him. But in any case, I want myself the same in the future. Also had a problem with playback and acquired an adapter for listening to music
  14. Mendel Leisk
    38,705
    Yup, just run a wire from the phone's headphone jack.
    There's another trick, almost an Easter Egg in this day-and-age: the head unit is actually an am/fm radio. I guess the problem though: fm has turned into commercial laden dreck. :(
  15. Calimobber
    Calimobber Member
    94
    82
    Death Valley
    For music this is the coolest little bluetooth adaptor. Its powered off the usb port next to the aux plug and will automatically turn on when you start the car since the usb turns on. then will automaticall shut off with the car so your music or podcast stops immediately after shuting down the car. Buy the ground filter as will since the usb and headphone share the same ground it give you a hum if you dont use the filter.
  16. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    We put a grom into my son's 2005 and it's been great for a long while now. About $149.
