Sole owner of 2002--quirks to expect
Discussion in 'Generation 1 Prius Discussion' started by Lepidopteress, Mar 4, 2021.
  1. Lepidopteress
    Lepidopteress New Member
    Albuquerque
    2002 Prius
    Hi!
    I am new to the group, though a long time Prius owner---got my 2002 at end of 2001. It currently has around 220,000 miles, and I have replaced the hybrid battery once about 10 years ago. I figure it may have to be done again in the near future---which I will do because I really like this car and know its history. I have really not had to have much done to it, and it has saved me thousands of dollars in gasoline over the years and tons of CO2 that has not been spewed by using it.
    I do want to share a few of the quirks of my older car though so if any of you have bought one used, you know what kinds of things to expect. Mine has been serviced at the original dealership by a mechanic I trust totally.
    Headlights---I am sure you know the plastic can get pretty cloudy and needs to be polished now and then for optimum transparency.
    Front windshield--prone to chips and sand blasting due to the angle and size
    Door locks---my auto locks on the back passenger and now the back driver's side do not always work. They seem to do better in cold than in heat. So, I just check the doors.
    Upholstery and dashboard---indestructible.
    Indicator lights:
    Power Steering--on longer trips, this light will sometimes come on, sometimes followed by a failure of the power steering, which unless you are super weak or driving a competition, is not a big deal. Usually, it will go off if I shut off the car for a few minutes. Quite often it happens about the time I am needing a break anyway, so we call it the bathroom indicator light. Have conferred with my mechanic that it is not a major issue. Happens more often in hotter weather.
    Check Engine---more disconcerting, this happens pretty randomly, maybe every hundred or so miles. In this case it is related to the catalytic converter. It could possibly keep it from passing an emissions inspection, but not necessarily. This can be reset by disconnecting the aux battery cable.
    Inverter Assembly (Hybrid system)---in the gen.1, the code for inverter assembly also includes the inverter cooling pump. In the newer cars, the inverter pump has its own code. So, if you get that code, it could be the inverter itself $$$$, or it could be just the inverter pump. One mechanic did not know that, and wanted to replace the inverter. I got a second opinion from the guy I usually use, and he said more frequently, it is just the pump, much less expensive! When this goes out, your car will limp to the side of the road, and when allowed to cool, you can limp forward a bit at a time.
    Brakes---mine have lasted forever.
    Shock absorbers---I had replaced at roughly 15 years I think.
    Auxiliary battery--the little one in the trunk--these guys are not as expensive as the main battery, but will be over $200. That caught me off guard the first time.
    Main battery--I replaced at 10 years---expect to spend about $2000. If buying used, make sure you have proof of the age of the battery. That will impact the insurance value of the car if it is ever totaled. I had purchased a car once primarily for the refurbished battery, but had no proof of that so it was not included in the insurance value. Some people replace just cells---or have them replace. I feel like that is kind of like replacing one of two batteries in a flashlight---the second one is usually not far behind.
    That's about it! I have enjoyed my car so much, and hope that anyone out there who is adopting an older one like mine will enjoy theirs as much! But do watch out also---some drivers out there really have it in for anyone driving a Prius.
    mroberds, Prodigyplace, ammdb and 2 others like this.
  2. Tideland Prius
    16,445
    That's awesome! Thanks for keeping one of the Classics on the road!
    That's the thing about older cars - most people (me included) would rather spend the repair bill on a downpayment on a new Prius rather than update or repair the old one.
    Prodigyplace likes this.
  3. ChapmanF
    17,355
    Years of heat and UV can take a toll on those plastics, making them brittle if you ever need to remove them (say for replacing instrument panel light bulbs, which also could be burning out around this age). I shot a video with advice on getting the center finish panel out in one piece.
    That indicates a failing torque sensor inside the steering gear. It mostly leads to symptoms like you've described, or moments where the steering wheel will shake like a wet dog. A very few people have reported that it actually powerfully spun the wheel on them in one direction or the other. That should be extremely rare, because the torque sensor has two independent elements mounted in opposite directions, so even when they are both electrically noisy, they normally won't agree on a direction, so the steering computer knows it is getting bad data, and won't act on it.
    There was an extended warranty on the part; mine got replaced for free around 194,000 miles. But that's expired now, leaving the intrepid DIYer to potentially digging out the torque sensor for cleaning.
    The Gen 1 has other sensors that are built the same way and cause similar nuisances when in need of cleaning. The accelerator pedal sensor will create the "Big Hand Syndrome" (feels like a big hand reached down from the sky and slowed your car down). The position sensors on the heat-A/C doors will lead to a sound like mice scurrying back and forth under the dash. Those are easy to clean. The accelerator pedal, not so much (the sensor case is glued together).
    Ideally, you're inspecting those regularly, though. I do at each tire rotation. Often no new parts are needed, but you can catch developing problems in the bud that, if not caught, could lead you to needing repairs tens of thousands of miles early.
    Toyota sold Gen 1s with two different sizes of aux battery: an original one (GS Yuasa) of less than 30 Ah capacity, and a later, somewhat larger Panasonic, 45 Ah capacity (later further improved to 54 Ah). The larger battery also had larger terminal posts and required different clamps on the battery cables. A retrofit kit was available from Toyota to change out the battery tray and clamps in the cars that came with the smaller one originally.
    When replacing, it's good to know which one is in there.
  4. Trombone
    Trombone Active Member
    294
    101
    Allentown, Pennsylvania
    2002 Prius
    No reason to pay $200 for a 12V battery! Convert the terminal clamps to standard American size, and any 51R case-size battery will do, and there is a wide range of quality and price in that category. I currently have an Interstate installed, going on four years old. Given the sheltered location, the 12V should last at least five years, and typically much longer.
    2002 Classic owner here. Just turned 150K miles. Keeping it forever!
    dabard051 and WHCSC like this.
  5. dabard051
    dabard051 Tinkerer-in-Charge
    251
    93
    Rochester, NY USA
    2002 Prius
    Lepidopteress, congrats to you on keeping your Prius' longevity!
    Please invest in a code reader; even the cheap ones will give you a reasonable starting idea of where to look for a MIL/Check Engine problem, although code readers which will get deep into the weeds of subcodes (particularly for the Gen I) are very hard to find.
    I suspect that at some point, you will encounter P0420 and the Check Engine light will come on. That means the catalytic converter has reached end of life. You might extend its life by periodic use of a product called Cataclean, but I can't speak definitively. Being in NM, start looking around for an exact-fit replacement cat (Eastern Catalytic #40544 is one) and a mechanic to install it for you, unless you enjoy spending a half day under the car doing it yourself.
    Also, the HCAC mechanism after the cat converter periodically may need some lubrication with a high temperature grease. The HCAC mechanism is vacuum actuated, and so the short stretch of 1/4 inch rubber hose under the car from valve to the HCAC may start to dry out and give you grief.
    I'm in the Northeast rust belt, and so I have found that the gas fill pipe (that the fuel cap screws into) gets corroded and then won't hold a vacuum, which gives rise to Check Engine and P0440. Sanding away the corrosion and smoothing the fill pipe, as well as removing any rust which may get embedded in the rubber gasket of the fuel cap, solves that issue. Give your fill port an inspection; it may not be an issue, given your location.
    But other than that, you seem on top of things. Best wishes for many happy miles may you and your Prius enjoy ahead!
  6. ChapmanF
    17,355
    Oh right, I had forgotten that detail. Advised by PriusChat, I had slid under there preemptively and worked that valve back and forth while applying some anti-seize at its shaft. Never gave me any trouble. I am not certain that recovery is as easy if one waits for signs of trouble first.
