Solicited CAN Messages, Anything special required?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 2k1Toaster, Aug 13, 2012.
  1. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes the scope does it automatically. I needed a second source of verification since it appeared I was sending and receiving OK from my home-brew board.
    It is an Agilent MSO7054A with all the serial decode goodies. It decodes in real-time, even has a lister to display multiple messages. So I can set it up to trigger on specific events, errors, SIDs, data bits, anything. I also have a smaller and older 54624A which can trigger on CAN SOF signals but not decode.
    lopezjm2001 and 2009Prius like this.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I can but I don't fully understand the question. I just got solicited messages working, I don't even know how to decode the hex yet!
    It would seem that I send the message as I have, but then send SOF 0x7E3 0x08 0x30 0x00 0x00 0x00 0x00 0x00 0x00 0x00 CRC EOF 5 times and calculate the total time between the first request and the last data frame back?
    And what do you mean by "CRO screens"?
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I believe you only need to send the acknowledgement frame once after the first reply coming back.
    I think he meant the arrival timing of the reply frame 1, frame 2, etc. and by "CRO" he probably meant "DSO" (your MSO).
  4. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    For ISO 15765-4, the DLC is always 0x8. If your data length is shorter than 8, then trailing padding zero's must be added to make up 8 bytes.
    PCI (Protocol Control Information) = 0x02 (1st byte)
    Data = 0x21, 0xD0 (2nd & 3rd byte)
    Padding zero's = 0x00, 0x00, 0x00, 0x00, 0x00 (4th to 8th byte)
    Vincent
