Solid, high-pitched tone on start-up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by timwalsh300, Oct 11, 2023.
  1. timwalsh300
    timwalsh300 Member
    131
    16
    In the last month or two, half a dozen times now, I've heard a solid, high-pitched tone for maybe five seconds after turning on my car. It's a higher pitch than the beeping tone that I hear when the car is in reverse. It's definitely an electronic tone, not like something mechanical is squealing. No caution or warning lights accompany this tone. After about five seconds, it stops and everything seems normal. It doesn't happen every time, like I said, it has been maybe once every week or two lately.
    Maybe I haven't searched hard enough, but I haven't found any certain explanation for this yet. Does anyone know what it is?
  2. ChapmanF
    18,899
    There's only one solid high-pitched tone buzzer that I know of, though I'm puzzled at you saying there are no warning lights.
    You could pop the hood one morning and take out the ABS-1 (25 amp) and ABS-2 (30 amp) fuses, then start up the car. See if you recognize the same high-pitched tone, and see if it now continues, instead of stopping after a few seconds. If so, I'm right about what sound it is (and then there's just a separate question of why no warning light is on with it).
    ABS-1 is a 25-amp small blade fuse in the portion of the fuse box with a bunch of small blade fuses. The 30 amp ABS-2 is one of the larger fuses, not right next to ABS-1.
    If I'm right about what the warning sound is (or, better, starting now and until you're sure I'm not right about what it is), wait for it to stop before you drive away. It is the warning tone that you haven't got enough brake fluid pressure on hand to dependably work the brakes.
  3. timwalsh300
    timwalsh300 Member
    131
    16
    Do I need to try it in the morning? So that everything is cooled down? I will try it and report back.
  4. ChapmanF
    18,899
    It's not so much a matter of 'cooled down' as of when the pressure is low. The brake fluid is kept under pressure in a fluid accumulator that may lose pressure slowly. In the morning its pressure is often low after sitting there overnight, and a small pump under the hood pumps it back up. If that takes more than a few seconds, you get the warning.
  5. timwalsh300
    timwalsh300 Member
    131
    16
    @ChapmanF I was in a rush this morning, so I didn't get to test this. But I did have a couple of relevant thoughts: I've been driving the car for more than 15 years now, so I have an intimate feel for what's normal and what isn't. Over the last couple of months I think I've noticed that the pumps - the ones that run after shutting the car off, and (I think) upon opening the driver's door to get in and start the car again - seem to be running more. Also, once, and only once, I remember the brake pedal feeling funny when I had just started the car and was backing out of a parking space. Like maybe I had to press the brake pedal a little harder than usual, but then it seemed normal again. Both of these things would point to your theory, right?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    If it's related to the braking system, then I would expect it to set some codes (?) in the ABS ecu. I might try connecting a capable scantool (ignition ON, not ready) and look at ABS data - specifically ACCumulator PRESSure (normally the pump turns on when ACC PRESS goes down to around 3.2V and pump off around 3.6V).
    Step on the brake pedal a few times before powering up the car - can you tell if the brake pump runs a bunch or just a few seconds?
    If all brake pressure bleeds off (very "low" voltage), then the audible warning (beeeep) might sound off until pressure builds high "enough".
    OR, if this only happens after you switch to READY on a cold start, then I might wonder if it was the Coolant Heat Storage pump making noise. When they start acting up, they make a peculiar "squalling" that doesn't sound like most mechanical faults. Can't tell without hearing your sound.
  7. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Curious, how old is the 12v battery?
    Likely not your issue, but others have found a correlation where the accumulator cycles more often when the 12v is at a low state of charge.
  8. timwalsh300
    timwalsh300 Member
    131
    16
    I didn't realize it until now, but it's pretty old... I last changed it in 2017. Time flies.
    Today I finally went to take out those ABS-1 and ABS-2 fuses and try starting up the car, but I got stuck on how to actually remove them. I found them but didn't see an obvious way to access the smaller one. To remove the bigger one, do I just pull real hard? I was worried about breaking something.
  9. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    #8 SFO, Oct 15, 2023
  10. ChapmanF
    18,899
    Look around the fuse box for a little white plastic fuse grabber stowed in the corner. That's what works for the little ones all packed closely together.
    They didn't provide a grabber for the larger fuses, but those are easy to buy at an auto parts store. I keep one in the glove box with my spare fuses and bulbs. :) You can usually pull a big one out without a grabber, if you have to, and you're patient enough. It's more about wiggling and pulling and wiggling and pulling and keeping that up for a long time, than just pulling real hard.
  11. timwalsh300
    timwalsh300 Member
    131
    16
    I realized that yesterday I was looking at the ABS No.1 relay ("the bigger one"), not the ABS-1 fuse. Today I found the correct 25A ABS-1 and the grabber and I was able to remove that. Now I don't see anything to remove where the diagram shows the 30A ABS-2 fuse, even after successfully removing the clear cover. I tried starting up the car anyway, and I got the ABS light but no audible tone.
  12. ChapmanF
    18,899
    Oh wait, you mean ABS-2 is one of the links that is part of the white "unit A" thing?
    Yeah, I see now that it is. My bad, sorry, those don't come out separately. I kind of hate the way other places in the wiring diagram give them their own names and show them as if they were separate fuses.
    Oh well, pulling the ABS MTR 2 relay ought to do the same trick as pulling the "ABS-2 fuse"....
  13. timwalsh300
    timwalsh300 Member
    131
    16
    Keeping with the pattern of about once per week, it happened again today. This time I did see the ABS light along with the tone. The light was probably on before too, but I didn't notice because it happens quickly. Tomorrow I have an appointment with a repair shop. I'm having them change out the 12V battery among other routine things, and I'll see what they think about the ABS.
    I'll note that this has never happened after the car was sitting in the garage overnight. Like today, it has happened after getting back into the car to drive home after running a brief errand somewhere.
  14. timwalsh300
    timwalsh300 Member
    131
    16
    I got the car back from repair shop #1 today. They did some routine maintenance and diagnosed the ABS for me, but said that they couldn't actually do the repair on the ABS. Their notes are below. Now I'm trying to find repair shop #2...
    Pending codes: C1253 Hydro Boost Pump Motor Relay Fault, C1256 Accumulator Low Pressure Fault. Voltage from the pump to the accumulator pressure sensor would repeatedly build up and then drop to 0 V. ABS actuator should be replaced and reprogrammed.
  15. timwalsh300
    timwalsh300 Member
    131
    16
    Here's the end of my story:
    On the 20th I read a few other threads about the ABS issue and got nervous about continuing to drive my Prius. After calling half a dozen independent repair shops, nobody could see it in a timely manner, and two people said that I'd probably need a Toyota dealer for this job anyway. One dealer was able to take it that same day, so I went there.
    They ran some tests that triggered the same C1253 and C1256 codes, and unsurprisingly said that I needed to get the whole ABS assembly replaced. It took them a week to get the parts and finish it. The total cost (parts, labor, taxes, etc.) was $2,800. That was more than I was hoping to pay, but they also gave me a "free" rental car for the whole time which was convenient and probably worth a few hundred dollars.
    Driving my Prius home today, I noticed that the pump was running MUCH less than before. I think now that the ABS was struggling for longer than I realized, and I just got used to hearing it.
    I know that a lot of people would have balked at paying so much to repair a car that's nearly 16 years old, and maybe not worth much more than $2,800 itself, but it was well worth it to me. I was just reading yesterday about someone encountering an 18-month waiting list to buy a new one... no thanks. I'll keep repairing this one for as long as I can.
    #14 timwalsh300, Oct 30, 2023
    dolj likes this.
