Featured Solid-state battery wars
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Jan 16, 2021.
  1. Gokhan
    Gokhan Senior Member
    6,710
    2,660
    Paramount CA
    Yes, the leading manufacturers would have had the edge if they had the technology. However, they don't. Toyota is believed to pursue the sulfide solid-state separator developed by a Japanese professor, which is destined to be doomed. We'll see their demo car running on a solid-state battery they promised if they decide to still show it.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I think you've entirely missed the point - the Sion battery isn't considered "solid state". It's close to solid state, using a ceramic-polymer barrier, a very small amount of liquid electrolyte, and a lithium-metal anode. It's not an all-solid-state battery, it's just a better battery than either QuantumScape's or traditional lithium-ion.
  3. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    A major manufacturer pursueing a doomed solution?
    Hard to believe, I wouldn't bet on that.
    Trollbait likes this.
  4. Trollbait
    12,817
    "due to the potential of short circuits in the cell modules." Specifically an insulation defect in the module.
    Inside the cell module is outside of the cell. This is a fault outside of the battery cell's interals, but inside the pack.
    Even if within the cell itself, such faults can happen with any chemistry. GM recalled the Bolt twice to replace the battery over manufacturing defects. Each time they studied the bad batteries to determine the exact fault, and improved the manufacturing process to reduce or eliminate it from happening again. This is normal, and will likely be more common with a new battery type.
    How many batteries has QS massed produced and installed in buses?
    When did 4 layers become dozens? QS doesn't even hit the cost requirement. Which are targets they have set. When Li-ion can go for >1000 cycles, why is >800 good enough for solid state?
    They are also partnered with a ceramics company that makes capacitors. Which use what for separators?
    But QS has declared it doomed, so it must be.
    telmo744 and austingreen like this.
  5. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    This represents a problem for all solid state batteries, but it is minor if you read it.
    They were not recalled because of operating temperature but because of manufacturing defects. Quantum scape is having trouble even manufacturing small quantities right now. They hope to be able to manufacture meaningful samples in 2023. These are likely to be expensive even according to quantumScape initially.
    On the temperature issue, from your link -
    All solid state batteries in automotive applications that want wide distribution are going to need to heat the batteries including quantumScapes which although they work down to -30 degrees C they do not charge or provide power well at lower temperatures. Auto manufacturers currently use liquid conditioning to heat and cool their batteries. Its relatively simple to tell them to stay at the proper temperature or have them warm up. This does use power from the batteries though.
    The bigger problems for the Bolloré batteries is the cells have an energy density of 250 wh/kg and do not allow for fast charge rates. This was better than lion in 2012 when introduced but not very good now. The panasonic lion cells in tesla battery packs are 260 wh/kg. The lion battery packs in the ioniq 5 claim to be able to charge 10%-80% in 18 minutes. Still we do have working solid state batteries in vehicles they just don't provide real benefits today.
    I really don't expect any of the better solid state technologies to be in a high volume car for at least 7 years. Manufacturing is tough and these costs are going to be high. But we do have a lot of contestants and computing power is helping make material choices easier to check out. We may see nio and toyota with demonstrator cars this year or next, but ... costs and manufacturing problems are going to take awhile to iron out.
    This is part of QuantumScape's disclosure statement.
    #105 austingreen, Mar 11, 2021
  6. Gokhan
    6,710
    2,660
    Paramount CA
    QuantumScape is continuously testing their batteries, as the cycle testing requires many months. So far, they have reached around 1,000 cycles, but the testing isn't finished. If you extrapolate their graphs, 80% fade seems to be reached around 2,000 cycles. Lithium-ion standard is 80%.
    They are in the process of making 10–12-layer-cell by the end of 2021. They announced the 4-layer cell only weeks ago.
    They will produce battery packs for 100 EVs for their various OEM customers in their QS-0 prepilot factory in San Jose in 2023. If all goes well, the commercial batteries will be sold in 2024.
    This is a special ceramic with a chemistry kept as a trade secret. I don't know NGK etc. makes them or have the manufacturing facility to make them. It is a big part of the manufacturing process.
  7. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That's a lot more speculation and extrapolation combined with assertions that QS can do what they claimed but no one else can.
    If you look at their "Solid-state battery landscape" (which you provided) they only reached 1000 cycles on the 1 layer design, and that one did not meet their own requirement of working at ambient pressures and low temperatures.
    QS looks like a looser to me. Probably bankrupt or bought out for their patents by the end of the year.
  8. Gokhan
    6,710
    2,660
    Paramount CA
    Nah, their cells work, and everything has been falling into place ahead of schedule so far. If they fail, no one else will be able to achieve an all-solid-state battery in the next ten years, and the EVs will not be mainstream despite whatever the Biden administration does in the next eight years.
  9. Lee Jay
    5,850
    4,036
    There's no evidence to support your unsubstantiated opinions, therefore they might as well be written on used toilet paper.
    salyavin and Rmay635703 like this.
  10. Rmay635703
    Rmay635703 Senior Member
    2,689
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    When I can go to Walmart buy one for $49.99 and put it in my car they might have a point.
    Until they are for sale we might as well argue who’s father is stronger
    Gokhan likes this.
  11. bwilson4web
    16,521
    No reason to visit the local Toyota dealer. Guess Toyota USA, SouthEast Region, and local Toyota dealers don't want my business.
    Gokhan likes this.
  12. Gokhan
    6,710
    2,660
    Paramount CA
    If all goes well, QuantumScape all-solid-state-battery-powered Volkswagen/Audi/Porsche EVs will go on sale in 2024. Other OEMs should start using their batteries shortly after. Before that, OEM EV testing will take place in 2023.
    Here is a world map by the ProLogium brochure I posted previously—definitely to be taken with a grain of salt. Note the death skulls.
  13. austingreen
    13,713
    4,231
    Austin, TX, USA
    QuantumScape has a lot of cash, it IPOed through a SPAC last year and raised $680M, which should be enough to get it through 2024. If it actually has a good battery design and they can manufacture it inexpensively, they likely can issue more stock or bonds to stay afloat as tesla did, until profitable. The most promising battery start up from the last round provides a cautionary tale. That was A123, that could not figure out how to manufacture inexpensively but burned through money fast. The company raised money in an IPO in 2009 along with large US government grants and Michigan tax incentives. They were sold in bankruptcy to Chinese manufacturer Wanxiang group a little more than 3 years after the IPO.
    That expensive Michigan factory that caused the A123 bankruptcy burn is now partially being used to produce solid state battery cells in partnership with ionic materials. I don't expect QuantumScape will burn money as fast as A123.
    #113 austingreen, Mar 11, 2021
    Gokhan likes this.
  14. Trollbait
    12,817
    What reason is there to trust their publications less than QuantumScape's? They actually have a battery for sale now.
  15. Gokhan
    6,710
    2,660
    Paramount CA
    You must be very naïve not to trust a US-based, Stanford-origin, and VW-backed company but to trust anything coming from that part of the world.
    No, ProLogium does not have an all-solid-state battery (ASSB), which is defined by a lithium-metal anode. Chances are that they will never have an all-solid-state battery because they do not have the technology. Incremental improvements such as by ProLogium on the existing lithium-ion batteries that come at exponential costs will never make it to the EV market.
  16. Lee Jay
    5,850
    4,036
    You must be very naïve not to trust a US-based, Brookhaven National Lab origin company whose products have already been used by Airbus Defense and Space and is already available in a large-size multi-layer version.
    Oh, so Sion's Liceron is an all-solid-state battery (ASSB) since it has a lithium-metal anode, despite having a small amount of liquid electrolyte.
  17. bwilson4web
    16,521
    Develop a 200 C (400 F), solid state battery and I'll buy it.
    With a melting temperature of 180 C, a melted lithium anode will NOT form dendrites. Of course super insulation will be needed to handle the heat loss. So give me a hard problem.
    Better still, a Sodium, solid state battery with a 100 C melting temperature. Sodium is as close as the nearest, salt water ocean. Cutting the melting temperature in half simplifies the thermal insulation.
    #117 bwilson4web, Mar 11, 2021
    Gokhan likes this.
  18. Gokhan
    6,710
    2,660
    Paramount CA
    I trust them, but they are showing only a 300-cycle life with 25% quick charging, which probably translates into 100 cycles with all quick charging. This is not sufficient. They provide very little data, which is not encouraging either. If they ever think they have a feasible battery for the EV market, they will go public through a SPAC as QuantumScape has done.
  19. dbstoo
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    When your main criteria for company credibility revolves around whether they have gone "public through a SPAC" tells me you are shilling stocks and not really concerned with the technology.
    Dan
    salyavin and bwilson4web like this.
  20. Gokhan
    6,710
    2,660
    Paramount CA
    It's not inside information. I posted Sion Power's NASA presentation earlier in this thread.
    They don't seem to have solved the problem of cycle life, barely reaching 700–800 cycles in controlled conditions and doing pretty bad with fast charging. It's not to mention that their cells require pressure plates held by screws, which will add weight and volume, and they are not disclosing the pressure required. I think their problems boil down to their composite polymer/ceramic solid-state separator, about which QuantumScape says that it results in the "worst of both worlds."
    However, Sion Power is also claiming that QuantumScape will have to license their patents. That will be interesting to see.
