Featured Solid-state battery wars
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Jan 16, 2021.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    You got any other 400 or 500kWh/kg batteries?
  2. Gokhan
    Gokhan Senior Member
    6,710
    2,660
    Paramount CA
    Sion Power seems to be a reasonable contender. Their advantage is that they already have a pilot factory in Arizona, something which QuantumScape won't have for another two years. Their cells are promising, albeit they seem to have less than 1/3 of the cycle life of QuantumScape cells under 4C (60/4 = 15-minute) charging (about 80 cycles vs. 260 cycles from limited and indirect data available), as their polymer/ceramic composite solid-separator is probably not nearly as good QuantumScape's all-ceramic separator. This could be a deal breaker; however, they could also improve on that. Last but not least, both Sion Power and QuantumScape cells are lab cells at this point, and they can both have serious problems that could prevent their commercial application.
  3. Gokhan
    6,710
    2,660
    Paramount CA
    @Bob Wilson, QuantumScape says that if the lithium metal melts, it won't react with their ceramic solid-state separator, making the battery explode along with the car. I don't know if this is the case with the competitors who use polymer solid-state separators and/or liquid electrolytes.
    #123 Gokhan, Mar 12, 2021
  4. Lee Jay
    5,850
    4,036
    Oh, I thought QuantumScape was 20 years ahead of everyone.
    You're forgetting their nearly 2x energy advantage, meaning the same charging rate (in watts) results in around 2.5C, not 4C.
    salyavin likes this.
  5. Gokhan
    6,710
    2,660
    Paramount CA
    QuantumScape started their solid-state battery research before Sion Power did. Sion Power was originally working on the lithium–sulfur chemistry, which they gave up in 2015. That's why they have a pilot facility, as it was previously making lithium–sulfur cells.
    I don't think you know what 4C etc. means. It is not an absolute charge rate. 4C means charge to 100% SOC in 1/4 hours etc.
    It doesn't work that way that you can make up for short cycle life by high capacity. It doesn't matter if your cell achieves 10,000 W·h/kg if it doesn't have the cycle life. It doesn't matter if you have a battery factory if you don't have the technology. This is an all or none business. Unless you achieve in all areas, you will fail to have a marketable product.
    Also note that, unlike QuantumScape, Sion Power will never make commercial batteries. They aren't planning to build a production factory. They hope to license their technology to existing battery manufacturers.
    #125 Gokhan, Mar 12, 2021
  6. bwilson4web
    16,521
    High temperature batteries are well known in missile technology but typically as one-time-use, primary cells. I'm speculating that temperatures high enough to keep the alkaline metal anode liquid solves the dendrite problem. It would mean different separator and cathode materials. Given the market of cell phone, laptops, and pads using today's solid-state batteries, what could go wrong?
    Gokhan likes this.
  7. Gokhan
    6,710
    2,660
    Paramount CA
    Looking over Sion Power's patents, they are probably using a 9.7 atm (98 N/cm²) pressure on their cells. According to the QuantumScape's comparison table I posted earlier, above 10 atm is not acceptable. QuantumScape is using 3.4 atm, and even that is higher than the desirable 1 atm.
    US20200091547A1 - Application of force in electrochemical cells - Google Patents
    So, a cell that can't even reach the industry-standard cycle life of ~ 1,000 cycles at 1C (1-hour) charge at a moderately high pressure of 9.7 atm (142 psi) that borderlines the unacceptable pressure range and still not having a decent cycle life at fast charging is not very likely to be marketable. In fact, in their patent they go up to 19.3 atm (196 N/cm² = 284 psi); so, the pressure they used for their EV battery packs could be well in the unacceptable range.
    Their composite solid-state separator is a polymer mesh filled with ceramic—not a very ingenious invention. On the other hand, QuantumScape's all-ceramic solid-state separator is the result of many years of hard material science by Stanford researchers.
    US20180230610A1 - Ceramic/polymer matrix for electrode protection in electrochemical cells, including rechargeable lithium batteries - Google Patents
    The next couple of years will be very interesting in seeing how the progress on the field of solid-state batteries is made.
    #127 Gokhan, Mar 12, 2021
  8. Gokhan
    6,710
    2,660
    Paramount CA
    Extrapolating QuantumScape's data (see their February 2021 shareholder letter) on their multilayer cell is giving a life of around 3,000 cycles at 1C (1-hour) charge/discharge and 80% fade. This is three times the cycle life of the lithium-ion industry standard and five times the cycle life of the Sion Power cell, and they are using only 1/3 of the pressure Sion Power is using (3.4 atm vs 9.7 atm (or higher)). This is very impressive, and things like this is what is setting QuantumScape apart from the competitors in achieving a practical commercial EV all-solid-state battery.
    #128 Gokhan, Mar 12, 2021
  9. Lee Jay
    5,850
    4,036
    LOL!
    I'm an EE specializing in power and I've owned high power batteries in quantity since 1986 - NiCd, NiMH, lithium polymer and lithium ion.
    I don't think you understood what I said *at all*. Read it again and see if you can figure it out.
  10. Gokhan
    6,710
    2,660
    Paramount CA
    No, I am an EE and a PhD in solid-state physics, and everything is clear. The OEM is going to demand a certain kWh capacity, regardless of the specific energy. Sure, the higher the specific energy is the better, but the OEM is not going to even consider Sion Power's cell that lasts for only 640 cycles to 80% fade. On the contrary, QuantumScape's multilayer cell is lasting for around 3,000 cycles to 80% fade according to my extrapolation. It's day and night. You probably need 3,000 cycles because the cycle life is a lot shorter with 4C quick charging. It's not to mention that QuantumScape's required pressure is 1/3 of Sion Power's. When it comes to feasibility, most companies like Sion Power won't be able to deliver a commercial product because of poor performance specifications in various areas. You will see in a year or two.
  11. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    I'm not a scientist by any stretch of the imagination, as most posting in this thread already know. I was named after one, but what's that mean in the overall scheme of things. not much, even to me, except maybe the load.
    I took the pic below a few days ago. I first noticed it about a month ago, but it took this long to fit it into the schedule of recording it. It's frozen electrolyte for a spent flooded lead acid battery.
    Anyone interested in dendrites and/or battery whiskers of any kind, might also be interested in some real world data to accompany their own research of batteries. There are other kinds of dendrites anatomically speaking, although some might consider those non relevant to the discussion or too far a stretch to include, but I thought I'd mention it anyway with the hope that it's not worth the aggravation to over discuss the dissimilarities.
    Anyways !
    Gokhan likes this.
  12. Lee Jay
    5,850
    4,036
    Bad assumption.
    Even worse.
    80% of 250 vs 70% of 400. Hmmmm....
    Why wouldn't you just do what we do now on our current lithium ion batteries and not use the full capacity? Using 100% of 250 vs using 70% of 400 will result in the later having probably 10 times the cycle life - and more available energy.
  13. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    sion is not solid state (solid electrolyte and electrodes) it has a lithium metal electrode and a polymer separator (possibly electrolyte) with liquid electrolyte. I would definitely call it a lion although it's lithium electrode gives it an energy density higher than any other candidate with samples for automotive (400wh/kg) announced a week ago. These liquid electrolyte batteries with improvements sion, storedot, and the usual candidates mean solid state needs to get a lot less expensive to compete. Sion may not get costs down enough to compete in automotive, but they do have less stringent requirements for unmanned areal vehicles that have batteries with 500 wh/kg-700 wh/kg. People will pay for the lower weight in that market.
    State of the art battery cells for inexpensive lion in a large pack
    cells 260 wh/kg, 700 wh/l
    Pack 165 wh/kg, cost in 2020 $125/kwh
    lithium iron phosphate batteries that have less energy density are in packs at $100/kwh
    Gokhan and Trollbait like this.
  14. Trollbait
    12,817
    One has a product available that someone can test themselves, and the other does not.
    Why bring VW into this? Does a company that committed fraud for over a decade have a better chance of detecting it in others?
    3PriusMike and dbstoo like this.
  15. Gokhan
    6,710
    2,660
    Paramount CA
    Sion Power doesn't plan to make their solid-state batteries but license them. Therefore, I expect them to cost about twice as much as lithium-ion batteries. I expect them to be marketed primarily for flight applications because of their high specific energy. I don't expect them to find much use in the EV market because of their high cost, short cycle life, and poor fast-charging performance.
    #135 Gokhan, Mar 13, 2021
  16. Gokhan
    6,710
    2,660
    Paramount CA
  17. Gokhan
    6,710
    2,660
    Paramount CA
    GM has partnered with this Singapore-based company founded by an MIT graduate called SES (formerly SolidEnergy Systems) to build a solid-state battery for their next-generation EVs.
    They are using a gel separator. They think they can somehow suppress the dendrites with a gel separator with a special chemistry. I hope they succeed, but knowing how hard and ferocious dendrites are, I don't give it any chance. According to QuantumScape's comparison table, their cell has a poor cycle life and current density.
    They also boast AI as their primarily distinguishing feature. Perhaps they can license the AI part of their technology to others and make some money.
    SES - A More Practical and Complete Approach to Li-Metal Systems
    #137 Gokhan, Mar 13, 2021
  18. Trollbait
    12,817
    In what way will it bridge the gap? Those links are very light on technical details.
    Ultium is a technology suite that will allow engineers to design packs for different vehicles for less cost. It can also adopt new battery chemistries as they become available. From the above links, and other reports, GM is still using Li-ion with it. There are improvements, but Li-ion has been seeing steady improvements to performance and cost. If that is all it takes to bridge the gap, then Tesla's new cells are doing the same.
    The announced range for the 2022 Bolt EV is the same as the current model's. It is a few miles short of the Model 3 SR+, but Tesla stated ranges are a full charge, not the 80% they recommend for daily use. So the Bolt might already have longer range for a daily drive cycle. 250 miles is what GM is saying for the EUV. Makes sense as it is larger than the EV, and likely has nearly the same battery capacity.
    Gokhan likes this.
  19. vvillovv
    4,336
    1,518
    NY
    It's really hard to get empirical data from obfuscated and purposely misdirected facts.
    I clicked on some clickbate here at PC yesterday and got my first look at 12 volt hybrid gel batteries.
    some info here
    Renogy AGM, Pure Gel and Hybrid Gel 12V 200Ah Deep Cycle Batteries
    I also searched out dendrites to help organize my post above yesterday and couldn't fit this link into my post than but I'll list it here today.
    Scientists pinpoint cause of harmful dendrites and whiskers in lithium batteries
    Besides the electrical and anatomical dendrites there are also these kinds which may give some that are interested in them some clues as to way there are so many different meanings for the word dendrite.
    What are Dendrites? - EWI
    Dendrite (metal) - Wikipedia
    Crystal Habits and Forms
    being able to understand each other, is it getting easier?
    Electric Future youtube channel shares some potential advancements
    #139 vvillovv, Mar 13, 2021
    Gokhan likes this.
  20. austingreen
    13,713
    4,231
    Austin, TX, USA
    I think you can really cut that down to high cost. If you have a 400 mile battery (approximately 100 kwh in an application like the tesla model S) then 600 cycles will get you 240,000 miles of range before second life, and even if they aren't suitable for the grid a chemistry like this makes recycling the lithium much easier and cheaper than conventional lion. This is not a start up, so I would not bet at all on them coming up with a chemistry so good that a manufacturer will pore the money in to get manufacturing costs down unless they get really cheap licensing.
    Like sion this company has a liquid electrolyte and a lithium metal anode. The anode has a coating that acts as a solid electrolyte and protects the lithium from getting unstable. They have tackled the dendrite problem but likely have not yet solved cost problems. In 2018 their drone batteries were said to cost $500/kwh and the automotive cells are new.
    https://media.nature.com/full/nature-cms/uploads/ckeditor/attachments/6903/WEB_PDF_2017-10-00_-_Batteries_Materials_Collection-_SolidEnergy.pdf
    Having a liquid electrolyte (be it a gel, polymer, or solution) makes it much easier to get higher energy densities, but in order to make them safe there is often a cycle life trade off. Hopefully they will find a combination of materials that will work. For now the joint venture with gm means they have a less risk to manufacture. GM is also bringing its patents along.
    you are looking at lead acid batteries. Think of a gel polymer electrolyte like a gel like toothpaste. It is more stable and smaller than building a battery with more liquid electrolytes and is much easier to manufacture reliably than a solid polymer electrolyte. The batteries in you cell phone are lithium polymer and its not solid its a gel.
    Gokhan likes this.
