Solve a battery mystery with me!
Discussion in 'Generation 1 Prius Discussion' started by RenHoek, Jan 18, 2020.
  1. RenHoek
    RenHoek Junior Member
    East Bay, CA.
    2001 Prius
    G1 Prius guy here... I've already replaced 2 blades in this thing, buttoned it all up and took it for a test drive. It ran fine for about 20 minutes and then the red triangle again and I had to limp home. This is the read out I got from Doctor Prius. It shows that section 12 is still low and now that I've got it all disassembled again I can't find these faulty blades. I've got replacements and I'm ready to go I just don't know where to put them. Screenshot_20191215-180449_Dr%20Prius.jpeg
  2. Mendel Leisk
    42,323
    Maybe a little easier to read:
    Aaron Vitolins likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Pretty sure block 1 is the first and second module from where the power cable connects to the negative terminal. Block 7 will be module 13 and 14 from that end of the battery. Block 12 will be the 23rd and 24th, and so on.
  4. Cosmo Tigato
    Cosmo Tigato Active Member
    201
    363
    Oregon, USA
