[SOLVED for $0] -- 2010 misfire, stumbling, stuttering, coolant loss, head gasket, etc. symptoms
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Atari, Mar 16, 2019.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,158
    6,316
    Texas Hill Country
    The head gasket has blown; the engine is next.
    Roberto Ramirez and Brian1954 like this.
  2. Roberto Ramirez
    Roberto Ramirez New Member
    Livermore, ca
    no code at all. I cleared them and they never came back since it no longer misfires. I do not need to smog untill June 2025
  3. Roberto Ramirez
    Livermore, ca
    I like I said, no use replacing head gasket on an engine close to 300k miles when I can swap with JDM motor for $500 more. I figured this hack would give me a week or two, but four months later here we are.
  4. Roberto Ramirez
    Livermore, ca
    I only ever cleaned the EGR and EGR cooler once and that was because I had EGR code and needed to clear it to smog back in June. In the past, I have cleaned just the throttle body, intake manifold and EGR pipe.
  5. BiomedO1
    BiomedO1 Senior Member
    3,629
    1,872
    SacTown, Ca
    You may want to scan for pending codes before going to the smog shop. A pending code doesn't set the CEL until it happens a predetermined number of times, that's determined by the OEM.
  6. Roberto Ramirez
    Livermore, ca
    I have a decent code reader and there are no pending codes for misfires. Car would pass smog. Strangely, I do see a replace hybrid battery code after swapping battery with one I bought of guy parting his car. I was getting Hybrid System Error messages and code with my last battery, but no Hybrid System Error with used one I put in. Not sure if the issue with installation or SW/ECU.
  7. Rollinscholz
    Rollinscholz New Member
    Conway, Arkansas
    Check the floor for a leak , Sounds like a head gasket leak , into a cylinder ,does it run better after it warms up ?
    My 2010 did this , I tried replacing the EGR but couldn’t get it off , and then started having this same symptoms , along with codes for cylinder misfires , then eventually the head gasket.
  8. bisco
    51,948
    6 year old post
