Solved my bad MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by JC91006, Nov 13, 2017.
  1. audiodave
    audiodave Active Member
    800
    272
    US
    Cleaning the maf sensor and throttle body could change things too.
  2. JC91006
    16,835
    8,606
    My car's mpg is still not up to where my other gen2 cars are at, I'm going to swap the MAF sensor from my 50mpg gen2 and see if anything changes.
  3. Mendel Leisk
    41,955
    Are they the same physically? Interesting. Hopefully same internally as well.
  4. JC91006
    16,835
    8,606
    Both are identical, 2005 package 2.
    The lower mileage one is the one with the lower mpg. Only 113000 miles. The one with 190000 gets 50mpg
  5. JC91006
    16,835
    8,606
    Swapped the MAF sensors today. Initial test drives were very positive, low 50mpg on both cars. Now this is strange....
    I'll drive them for a week and see what happens after a few hundred miles.
  6. audiodave
    800
    272
    US
    I changed mine and it didn't help. Got the best mileage with a dirty air filter, dirty t body and old sensor. Lol
    235,000 miles.
  7. audiodave
    800
    272
    US
    I suspect if you had reset the computer it just needs time to settle to low 40's mpg again.
    I'm ready to change my injectors and O2 sensor. Low 40's is alI get.
    Prodigyplace likes this.
  8. audiodave
    800
    272
    US
    Maybe that upstream o2 sensor is a little off. Thinking of changing mine. I'm sure it's efficiency is off after 236,000 miles.
    SFO likes this.
  9. milestoempty
    milestoempty Junior Member
    Annapolis
    Watching this...
    Just replaced the 12v battery in my car 2 months ago. Two weeks ago I did an oil change, air filter, and cleaned the MAF (111k) and now Im averaging 43k miles down from 49. Replaced my plugs about 20k miles ago.
  10. JC91006
    16,835
    8,606
    How's your tires and alignment?
    Raytheeagle likes this.
  11. audiodave
    800
    272
    US
    How many tanks of gas have you ran through? Assuming computer was reset.
  12. audiodave
    800
    272
    US
  13. Suzan OBrien
    Suzan OBrien New Member
    Fresno CA
    I was having horrible MPG... and still do. About a year ago I put in Platinum plugs hoping that would help, but it' didn't. I am getting 40 at 144K and good maintenance.
  14. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Any update? My prius is now down to 39mpg, while my brothers gets 44 same conditions throughout. So trying to figure out why. Also noticing some knock.
    Using the SK16R11
  15. JC91006
    16,835
    8,606
    I find most of my local driving is still on the lower mpg side. I attribute that to the 17" tires. On the highway, I avg close to 47mpg.
    I'm not sure if the spark plugs change did anything as local driving mpg is still around 41 mpg
  16. audiodave
    800
    272
    US
    Same with me, higher mileage on the highway than around town. Low 40's to high 40's on the highway. 237,000 miles on 15 inch wheels.
  17. JC91006
    16,835
    8,606
    On my other cars with 15" tires I avg over 45mpg no matter if I drive local or highway
  18. audiodave
    800
    272
    US
    Well most of my around town driving is short trips and cold starts. So the worst of milage.
  19. Erik Owens
    Erik Owens Member
    162
    59
    I know it is always wisest to check the engine components to fix issues with MPG but being a hybrid I would always check to see if they HV battery is doing well also. MPG can suffer on the engine side and also the HV Battery side mainly where the battery cell connections are bolted together. They can be corroded and/ or the battery can be slowly starting to discharge intermittently.
    Not to say that your main issue being your plugs but as always keep it in the back of your mind. 2005 model. Possibly past 100K like I have read. Plus Iridium shouldnt need to be gapped but plugs do depend on resistance and type of course.
    audiodave likes this.
  20. audiodave
    800
    272
    US
    Curious on the plugs, gap was not correct on mine. They needed to be gapped. 43 is a number not every gapper has.
