Some 2010 Toyota Vehicle Oil Change Intervals Officially Revised To 10000 miles/1 year (verified!)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hkazemi, Dec 22, 2009.
  1. frodoz737
    frodoz737 Top Wrench
    4,696
    2,495
    33
    My 2010 is going away next week @ +150K miles, but the 2015 received it's 10w-40 transfusion a while back. We drive "normal" and could care less about "maybe" loosing 1-2 mpg on a car that already gets better mpg than everything else not plug-in. But don't listen to me...I'm just a Mechanic. What do I know? ;)
    orenji likes this.
  2. orenji
    orenji Senior Member
    5,887
    3,488
    Any oil usage at 150k?
  3. frodoz737
    4,696
    2,495
    33
    1/4 liter and holding per 5K mile oci at +150K total miles. Not bad considering what happened at 86,510 miles.
    Holy Crap | PriusChat
    For the record, the only reason my 2010 is going bye bye is because I'm taking back the 2015 Prius I allowed my Son to use for College part 2. He has his degree and career now and needs a truck...so I'm allotting that money towards the Tacoma he's buying. ;)
    orenji likes this.
  4. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    Stanger has reported no oil burning with the use of 0w-20 mobil 1 @5k oci with 185k on the clock.
    Yes to 0w-20.
    Lightning Racer likes this.
  5. bisco
    51,897
    i change my oil once a year. that amounts to 6,000 miles and about 1,000 hv. might be considered severe duty since a lot of it is warm up.
    frodoz737 likes this.
  6. danlatu
    533
    1,363
    maryland
    Hot/Cold temps and short trips would also be considered severe duty.
    frodoz737, Mendel Leisk and bisco like this.
  7. Mendel Leisk
    41,406
    ^ Funny but true: often the less you drive it, the more often you should change the oil.
    ALS, frodoz737 and danlatu like this.
  8. kenmorem
    kenmorem Junior Member
    Puget Sound
    what is the forum's consensus (if there is one) on the best oil filter for the prius?
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Toyota P/N's:
    04152-YZZA6, replaceable element
    90430-12031, gasket
    orenji likes this.
  10. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    I make a lot of short trips under three or four miles at a time and I agree. I put on roughly 8500 miles a year which means that I get an oil change twice a year, every six months or 4,250 miles. At 78K miles I have seen absolutely no oil loss at this point in time.
    Merkey and Mendel Leisk like this.
  11. sguerra923
    sguerra923 Junior Member
    48
    San Diego
    Hey guys quick question, is this the oil that the dealership uses to do oil changes? Screenshot_2019-03-14-18-33-36~01.jpeg
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  13. orenji
    5,887
    3,488
  14. Mendel Leisk
    41,406
    Our dealership has bottled liters of Toyota 0W20. I used to purchased bottled from them, then switched over to bulk (the same stuff) maybe 3 years back. Besides being cheaper, I'm no longer dropping off empties at our local motor oil recycler.
    My price for bottled liters of Toyota 0W20 (back a few years) was $5.65 (CDN). For quite a while the bulk equivalent was $4.50 per liter, but in the last year it went up to $4.90.
    I also get Toyota 5W20 conventional in bulk, for our daughter's Pilot. Last time, it was a jaw-dropping $2.33 per liter...
    @edthefox5 will be along shortly to explain why I'll be going to hell, lol.
    #354 Mendel Leisk, Mar 14, 2019
    edthefox5 likes this.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Lol....right behind you my man right behind you...
  16. E46Prius
    E46Prius Active Member
    314
    220
    Costa Mesa
    FWIW, I use Amazon 0W-20 on my 2015 CT200h. I'm an oil snob in the past, using only the finest Mobil 1 euro in my M3s and other BMWs but switched to Amazon for my recent Lexuses.
    It has all the modern specs and designations up the wazoo and is really cheap. 10 years ago, this would be a no-go, but lower-tier suppliers have caught up. Check it out
  17. Mendel Leisk
    41,406
    The Amazon 0W20 is $22.99 USD for 5 (US) quarts, converts to around $6.48 CDN per liter.
    Up here I can get bulk Toyota 0W20 through local dealership, for $4.95 CDN per liter. It was $4.50 per liter for a few years, just went up a bit recently. I bring my own container (a 10 liter gas can).
    It has a few advantages: it's cheap, you're not putting motor oil contaminated bottles in the recycle stream, and you're not having jets flying your one or two bottles across the nation.
  18. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    How did I miss this one? Going into the new stash right....now.
    Mendel Leisk and m.wynn like this.
  19. HenryC121
    HenryC121 New Member
    Taiwan
    We get synthetic oil changes at the dealer for our 2010 Prius. Since the service minder comes on every 5,000 miles, and the recommended oil service is every 10,000 miles, should I just reset the service minder?
  20. Mendel Leisk
    41,406
    Yes. In the States Toyota says to rotate tires (and "visually" inspect brakes fwiw) every 5k miles or 6 months, whichever comes first.
