Some build\modification questions- packages make no sense
Discussion in 'Gen 4 Prius Main Forum' started by lohikaarme, Jan 24, 2016.
  1. lohikaarme
    lohikaarme Active Member
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    I went through all the builds and it would be great to take the spare tire from the prius 3/3t, the hud from prius 4 package and the led/fogs from prius 4t into a single car. I am not sure why they spread out everything the way they did but it is very annoying.
    I doubt the body changed between the models and the battery is probably the same size-
    Questions:
    1. Speculation: would the spare battery cavity is the same size across all the models and therefore can fit a spare in the 4/4t?
    2. Do you think that if you buy the fog light\LED assembly they can be installed in the 4? I suppose they wont be automatic DRLs and will need another switch for activation much like putting fogs into the gen3 4.
    3. Why would they totally exclude a HUD from all touring models? I do not care much about a moonroof but one would think touring would be driven on longer trips so the hardware would support the ability for less fatigue.
    4. Are these back to oil filters or still with the oil canister- also no mention on if there is another oil change trap door to contend with.
    5. Same MPG rating for 15 and 17 in wheels? really? I don't think so. Are the 17" magic Toyota wheels?
    6. Are there any differences in screen size across any of the models\packages the way the upgraded nav\sound system of the gen3 was .9" larger than the standard screen?
    .... and an extra $395 for red? come on
  2. arescec
    arescec Active Member
    238
    105
    Croatia
    If you think $395 is expensive for red, VW and Toyota in Europe ask upwards of $800 for special colors.
    This is for VW Passat:
    #2 arescec, Jan 24, 2016
  3. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    I don't get how it is now a special color. I former gen 2 and my current gen 3 are red. It has been on the menu for years.
  4. PR1U$
    PR1U$ Junior Member
    29
    Far Nor Cal
    Red auto paint is more expensive. Toners to make red cost more. If you buy paint to repaint your car a red color, it will cost you about double of a white or black color. The extra for the red is justified, in my opinion. It would cost you more than $395 difference for a red color if you bought it from a paint shop. Seems to me the manufacturer is absorbing some of the cost.
  5. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Misplaced my gen3 window sticker. I know I was not charged a premium for red the last two go-arounds. Regardless if it is justified or not, my point is this looks like a new charge with this generation.
  6. Mendel Leisk
    42,345
    Red is the color they use a lot for ads too.
    Regarding OP's questions:
    Probably, but expensive to accomplish, due to the both the cost of the spare and all the plastic/foam pieces.
    Again, likely doable. Be careful what you wish for: I have third gen stock "fog lights", they're pretty much useless, just look nice.
    Who knows. Personally I don't like sunroof/moonroof at all, HUD would be nice I guess. I despise the centered-on-the-dash instrumentation.
    That'd be interesting to know. Please, some DIY'r with 2016: have a look? Good time to start rust protecting while you're under there.
    I'd suspect the engine bay underpanel is very similar. FWIW, I take the whole thing off, for every DIY oil change, not that hard. Also, I like the oil filter canister, it's a step in the right direction, as far as recyling is concerned.
    No. They just have one rating, but I'm sure the 17" wheels impose a slight penalty. Maybe not so much as third seeing how the rims appear to be a lot lighter. Don't like the look though.
    No ideas.
    #6 Mendel Leisk, Jan 24, 2016
  7. Kenrico
    Kenrico Member
    82
    52
    Up until recently , I think , the only charge for color was the Blizzard White Pearl $395 .. when I read the specs for 2016 gen 4 ..it seemed they added another color as an option also.
    I haven't looked at the spare tire yet, previously was looking for a used plug in advanced..just for LED headlights, HUD , better speakers , and the dynamic cruise control... Now it looks like a pkg 3 with ATP . The park assist looks interesting for the wife ..but I don't think that was available in the Advanced plug in before ..this will have a moon roof to boot.
    I would pay for the special color ..the Blizzard really pops with limo tint windows .
    Kenny
    krmcg likes this.
  8. Mendel Leisk
    42,345
    When we were buying a third gen in 2010, the blizzard pearl was an extra $250 (Can). Pretty steep inflation going on; seems partly they've found a cash cow.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Manufacturers have discovered that enough people are will to pay more for certain colors so they charge more.
    Where have you been since 2007? The 16" wheels on the Touring will cause a hit. The 17" wheels on the V since 2010 cause a hit. For testing purposes the difference isn't significant enough for a different rating.
    The industry has changed. I guess too many people complained about too many used oil filters in the garbage dumps.
    The new Prius probably has a door in the bottom panel to accommodate an oil change. Hopefully it will be more durable. I don't know when mine broke off and it really doesn't matter. maybe the dealer will have one up on a lift so you can take a look for yourself. If not just crawl underneath the car in the showroom.
    While you're at it, pop the hood to see how easy it is to change the air filter and drop the glovebox to see who easy it is to change the cabin air filter.
    Toyota has their reasons for what they did or didn't do. Chances are that the Prius isn't going to be a perfect match for everyone. Can't please everyone.
  10. arescec
    238
    105
    Croatia
    I just now checked on the local toyota website for the Plug-in since it's still on sale (they removed the normal version):
    White: free
    Blue gray: $570
    Pearl white: $800
    Silver: $570
    Blue: $570
    So color fees were there 100% for the last gen too, as they are with all cars. Metallic and other fancy colors are usually extra afaik with all the cars.
  11. Mendel Leisk
    42,345
    That's a bare faced cash grab. Here in Canada, in 2010, was only the Pearl White had an extra here, and it was $200~250. Not sure now.
  12. arescec
    238
    105
    Croatia
    Well, fully loaded PiP gets up to $52,000 without incentives, $44,000 with.
    What's $500 for the paint.
    You have to consider that we have much higher VAT (25%) and import tax (20%), plus some other taxes.
  13. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Thanks for confirming red wasn't an extra charge and is new for g4
    I I at the dealer now. I have some engine shots. Still waiting to speak w someone. 12v battery moved into engine bay, engine filter easy to access. No word yet on canister oil filter. Trap door: yes
    #13 lohikaarme, Jan 24, 2016
  14. arescec
    238
    105
    Croatia
    Red wasn't even available :D
  15. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    seriously though, the only time I ever saw an extra charge for red was for the limited edition 2015 absolute red or whatever they called it that replaced the limited edition purple in the persona model. If only I could find my window sticker. No gen 2 had an extra red charge and I know gen3 up through 2012 did not carry an extra red charge. I cannot speak to 2014 or 2015.
  16. arescec
    238
    105
    Croatia
    There is no red prius in Europe that I know, hell this is first time I ever heard they existed. See: Search Results
  17. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    My current Prius before I added fogs
  18. eight08customs
    eight08customs Senior Member
    245
    583
    Hawaii
    The color red always cost more than other colors.
  19. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    When I saw the hypersonic red it was obvious that the color is an unusually glossy, intense red with a lot of depth. It reminded me of the candy apple red multi layered paint jobs on the custom cars I saw when I was a teenager. It is striking and well worth the extra charge.
    I think that the painting process involves an extra step at the factory as well.
