Some Insider Notes on the 2017 Prius Prime - Part 2
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Apr 7, 2016.
  1. DavidA
    2,349
    1,825
    Chicago western burbs
    The regular Gen4's covers come off from the back after one has removed the wheel via the lug nuts. But I don't see the lug nuts when looking at those Prime wheels, so I am also puzzled about this.
  2. Tideland Prius
    16,683
    The Prime comes with the same 15" alloys as the Gen 4. The aerodynamic wheel covers just happen to cover the lug nuts as part of the design. If you want exposed lug nuts, then put on Gen 4 wheel covers :) Or just leave the covers off and show off the alloys.
  3. DavidA
    2,349
    1,825
    Ew. Gonna be a bi**h to rotate the tires.
  4. Trollbait
    12,832
    That's your chauffeur's problem. You'll be too busy enjoying those comfy rear seats.
    Son of Gloin and jmarkd7 like this.
  5. Tideland Prius
    16,683
    ?? How's it different from the Gen 2, 3, and v? I see you have the V which has the 17" wheels but all 15" wheels since has had some sort of wheel cover (rings for the Gen 2)
  6. Trollbait
    12,832
    Well, you didn't have to remove the rings on the gen2 to get to the lugs.
    The Sable has caps over the lugnuts; they were thin metal over plastic. Taking them off required using the tire iron to pry them off, so you had to be careful to not scratch them or the wheels, and it was easy to bend the cover.
  7. bisco
    52,888
    pip has no wheel covers on 15".
  8. Tideland Prius
    16,683
    Picky, picky :p but yes, you're correct.
  9. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Easy. Pull the wheel covers off by hand. Lug nuts are right there. I had the covers off to fit my air chuck on the valve stems to check the tire pressure. Nothing to it.
    Son of Gloin likes this.
  10. DavidA
    2,349
    1,825
    ^ Are the wheels nice enough on their own to keep the covers off permanently?
  11. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I thought so. All the Prius look so much better with the hubcaps removed
  12. bwilson4web
    16,550
    Toyota has a nice Plus, Premium, and Advanced features comparisons:
    2017 Toyota Prius Prime Interior Specs & Options
    I was about to spend money on a combined GPS+dash cam solution. Seeing even the Plus trim has navigation, I can go with a simple dash cam and save about $100.
  13. sonomac
    sonomac Junior Member
    25
    US
    It may seem trivial but Why can't we have sun visors that extend so we can block sun coming into side window?
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    Many people find the Toyota navigation lacking. I know my son with his 2015 Prius v tried the Toyota navigation and them promptly went back to using his Garmin GPS.
  15. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    New Question:
    On the front fascia, in the blacked out area just underneath the Toyota logo, are two recessed pockets that I guess the front license plate bracket can fasten to for those states that require a front plate. But why did Toyota make these two pockets recessed rather than flat for aerodynamics for all those who do not need a front plate. Is there some other function that caused the need for the recesses?
  16. Tideland Prius
    16,683
    We've been asking for one since the forum started in 2003 lol.
    That part is acrylic. Toyota pre-drilled those holes so that there wouldn't be any accidents at the dealer when they're installing the licence plate brackets (mostly cracks or chips).
    As for being recessed, I'm not sure. I'm taking a guess but maybe load bearing (Again, to minimise the risk of damaging the acrylic part of the grille). I haven't seen the bracket in real life. Maybe a 3rd party will make covers for them.
  17. bwilson4web
    16,550
    Or perhaps a foam and fiberglass cover that matches the body color and makes the car look less like a hungry catfish. <grins>
    Still there are some interesting, recessed vortex generators on the surface (i.e., think golf ball.) A vortex generator spins the air so it 'sticks' to a surface and flows along the side. There are times when they work and times where it makes me wonder Wth?
    Bob wilson
  18. Trollbait
    12,832
    My guess is because of aesthetics.
    Then most places require a front plate.
  19. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    [QUOTE="bwilson4web, post: 2472530, member:
    Bob wilson[/QUOTE]
    Since I can not see the internal details of the recessed areas in any photos or videos I would assume the recesses are not ducts in order to be vortex generators. Can anyone who owns a Prime confirm that the 2 recesses trap air as opposed to letting air flow thru to an outside temperature sensor or something else that is located behind the fascia? Thanks
  20. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Photo in pdf showing the recesses right below and to the right and left of the Toyota front logo.
    It looks as if there is an opening on the inboard side of each recess allowing a minor amount of air to pass behind the front acrylic black fascia. But how effective is this once a front license plate bracket is mounted to some Primes?
    JacksonMs and drash like this.
