Some insider notes on the 2017 Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Mar 23, 2016.
  1. ttait
    ttait Active Member
    273
    163
    Southern California
    What part of 'MY seat is very comfortable' didn't you understand? :LOL:
    KrPtNk likes this.
  2. CTorPrius?
    CTorPrius? Member
    100
    16
    Wilsonville, OR
    Don't tell her, or let her drive. Do either with caution.
    sonomac likes this.
  3. Edward.Howard
    Edward.Howard Junior Member
    Charleston, SC
    The US roadblock has to do with meeting very stringent Federal Motor Vehicle Safety Standards and Regulations. Toyota hasn’t been able at this point (November 2016) to laminate the photovoltaic cells in a resin that won’t shatter during a rollover crash, however, the roof panels do meet safety standards in Japan & Europe.
    smartin737 likes this.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Gen 3 was available with a solar charging moon roof option. What happened since then?
  5. hill
    9,023
    link? Fiskar Karma had almost their whole roof done in solar - & came out amout ½ decade ago ....
    Toyota said it added too much to the cost
  6. Tideland Prius
    16,678
    Could be different manufacturer, different manufacture process, different materials, perhaps it's the fact it's a full length solar roof vs. a half length + regular moonroof, could be the shape of the roof, could be the different weight of the car (Gen 3 vs. Prime)
  7. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    See below to see how easy it is to add a 1KW inverter to the Prius.
  8. jmgrant
    jmgrant Junior Member
    La Crescenta, CA
    Any reason something similar (to the 1KW inverter) couldn't be done on a Prime? I've been using an inverter on my '07 Prius when I go camping and on telescope outings to power my electronics. I'm thinking of upgrading to the Prime and I'd like to keep the option.
    I wish Toyota would offer a ~500-1000W AC output option from the factory. Personally I'd take something like that over the (kind of gimmicky, IMHO) solar panel option any day.
    hill, bwilson4web and bisco like this.
  9. bisco
    52,819
    no reason at all, the operations are the same. pm bob wilson, he may be doing the same with his prime, he had it on his 2010.
  10. Tideland Prius
    16,678
    Like this?
    Toyota AC Outlet Supply Accessory (Not charging cable) | PriusChat
  11. DavidA
    2,349
    1,825
    Chicago western burbs
    That outlet accessory ^ is limited to 100 volt - the voltage of Japan. In theory, the 1000 watt converter project could be done in a Prime, but the 12-volt battery to attach it all to is now up front instead of inside the rear hatch. That makes it a bit more complicated, wouldn't it? (unless there's a 12v battery direct bus to wire to that is also somewhere accessible in the back of the car)?
    #331 DavidA, Mar 16, 2017
  12. Tideland Prius
    16,678
    Which is fine for camping as long as you're not plugging in a hair dryer or a kettle.
  13. DavidA
    2,349
    1,825
    Yet, isn't that Prime plug thingy some ridiculous price?
    EDIT:
    Tea kettle needs or not, that's some wacky pricing for a limited use item. If the dealer sold it, they'd probably add $1,200 or more.
    #333 DavidA, Mar 16, 2017
  14. Trollbait
    12,818
    Depends on how accessible everything is. If we are lucky enough to simply thread electrician fishing tape along the main power cable, or other conduit, running a cable from the 12 volt to back won't be too much harder. A stereo installation place could likely find the easiest way.
  15. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    You can buy a 750 Watt inverter from Harbor Freight for $39.00. It clips to the Prius 12V battery and runs, runs, runs...
  16. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Be aware that that inverter is a "modified sine" inverter, meaning it produces basically square waves instead of sinusoidal waveforms. That means power quality is low and some things will run hot and others will not run at all on such an inverter.
    For this reason, I have a 2000W modified sine inverter for heavy loads like refrigerators and a 300W pure-sine inverter for more sensitive loads like CFL and LED lights and electronics.
  17. Jeff Cohen
    Jeff Cohen Junior Member
    Dallas, TX
    2003 Prius
    I tried (see above) to reply to the Ford/ Toyota thread but not really sure how to do so. For me it is not just about the manufacturer but the local dealers. What is available and what the local dealers are known for. A great car sold by a shop I would never want to do business with is nothing. I have had very positive experiences with a Toyota dealer and awful ones with the local Ford dealer. That is why I am a Toyota buyer, why I have made repeated purchases there and will continue to do so. All vehicles have failings and drawbacks and so do dealerships. Go to one that works for you and buy what works best to fulfill your needs. The Prime has not really been available in Dallas as yet so getting acquainted with one before buying could mean a 2018 model. We have had good experiences with Prii and will continue to buy them in one form or another.
    #337 Jeff Cohen, May 3, 2017
    Trollbait likes this.
  18. Trollbait
    12,818
    Fair enough, there is a Toyota dealer here I won't step foot into because they required a credit check before telling to price of a used car. Perhaps I am lucky in having multiple dealers for each brand to pick through here.
  19. hill
    9,023
    They easily met fed standards on the Gen1 Fisker karma in the U.S. too - which although gimmick-ie (even though it had the highest output of any roof top solar), the juice provided was paltry.
  20. JerryCS
    JerryCS Prius camper with trailer hitch
    77
    Elk Rapids, MI
    Exactly, no fifth seat and no continuous cargo area with the seats down is a deal breaker for me.
