Some insider notes on the 2017 Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by Danny, Mar 23, 2016.
  1. Tideland Prius
    16,683
    Well the area will be larger just by the fact that it has a wave pattern.
    Hmm, typically it's 1-3 months before launch and more often closer to 1 month. Someone found out that production starts on the 30th of September. They may get some press vehicles for November and maybe launch in December? That's my guess. The L.A. auto show is in November and I think they'll also show the production version of the CH-R in North America at the L.A. auto show (NYIAS had the concept version). Perhaps they'll do media drives around that time to save cost (see the production CH-R plus drive the new Prime)
    KrPtNk likes this.
  2. Linus vanPelt
    Linus vanPelt Junior Member
    2017 Prius v wagon
    Hope they come up with some more inspiring colors. I'm tired of shades of gray. Bring back the Black Cherry red color.
    KrPtNk and Tideland Prius like this.
  3. Tideland Prius
    16,683
    I agree. One red and one blue isn't enough :).
    KrPtNk likes this.
  4. Trollbait
    12,831
    Limited color choices has always been the norm at Toyota.
    Just posted a link about the heavy duty Silverado in another thread for some other info, but it mentions the truck got three new colors for 2016, and they all are some shade of red.
  5. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    2017 Toyota Prius Prime Plug-in Hybrid - Overview
    KrPtNk and Felt like this.
  6. bisco
    52,863
    i'm getting excited!(y)
    Felt likes this.
  7. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Fantastic demonstration -
  8. Mendel Leisk
    42,355
    I don't understand, missing something? Current Prius have temperature monitors and a fan.
  9. bisco
    52,863
    someone posted that they heard there was no cooling at all.
  10. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    If you watch the video Sergio posted you will see at least one fan and ducting. Thankyou Sergio! I too am excited. Too bad Pearl S has so few km on her. But if one of the morons I see everyday on the roads around here manages to get me, it will be "Prime time". ;)
    ("Clowns to the left of me, jokers on the right!")
    Sergiospl likes this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    It's very easy to add an inverter to any Prius to supply emergency power. And, you can do it yourself for about $350, whereas the Toyota built-in version costs thousands.
    All you really need is a 12V to 110V inverter and a long extension cord. Then you'll have emergency power as long as you've got gas.
  12. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    I suppose this will also work with the engine off, as long as the traction batterry is filled? Then you can use the car as your (6.6 kWh?) home battery, instead of, for example, the home battery from Tesla.
    #132 Jan Treur, Apr 4, 2016
  13. bisco
    52,863
    hmm, you're tapping the 12v, so, i'm not sure if the hv will recharge it with engine off.
  14. Jan Treur
    240
    168
    Heiloo, Netherlands
    About the PiP it was once discussed in PC that when the car is On, the 12V battery is also charged from the traction battery, without the engine running.
  15. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    But the vehicle needs to be in ready mode and should be in "park" not neutral. That way if you drain the HV battery, the engine will run periodically after you deplete the EV charge in "hybrid" mode to keep some charge in the HV battery. It is also possible to use a higher capacity inverter (the 12v bus should not be asked to supply more than 80 amps to the inverter - about a 1 Kwatt limit) if you directly connect to the HV battery, but that is a job requiring more expertise.
    JeffD
  16. bisco
    52,863
    you may be correct. will it stay on, or does it time out after an hour or so? i guess you could keep hitting the button if necessary.
  17. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    I remember when the tsunami hit Japan there were people with the inverter option on their Prius who used their cars for auxiliary power. It was as far as I know a feature that worked without much hassle and in that case was extremely useful.
    I feel that offering this on the Prime in North America would be a very smart thing to do. Are there other plugins that have that option? It would set the Prime apart and would appeal to quite a few buyers and could form the basis for an advertising effort. I have periodically needed a generator and it would be nice to have the security of knowing that the car could serve that need. It is a hassle to keep a generator fueled and serviced in case of a power outage. Having the car as a source of electricity would make it seem tied to your home and having a plugin a sensible option to many buyers. Campers would appreciate it as well.
    Since this feature is offered in Japan, Toyota must have already worked out the engineering and weight problems. I know that it is possible to retrofit a car with an inverter, but it would be so much nicer if done at the factory.
    Tideland Prius, Sergiospl and bisco like this.
  18. bisco
    52,863
    agreed. it would be a huge bonus, and i don't think it is available on anything here yet.
  19. Jan Treur
    240
    168
    Heiloo, Netherlands
    For me info on such possibilities is quite relevant, as around 2020 to 2022 I would prefer to have a car that can also be used as a home battery in a safe and regular daily manner. In the Netherlands we currently get quite good conditions for selling produced solar energy to the companies (same payback price as you pay for energy that you use) , but this will end after 2020. If the Prime is able to do this on a daily basis, this would make it more attractive for me.
  20. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just remember that a Prius can produce some carbon monoxide when running (albeit a small amount compared to other sources) so provide for ventilation.
    JeffD
    Rebound and KrPtNk like this.
