Some measurements on 12V battery
Discussion in 'Gen 2 Prius Technical Discussion' started by David Beale, Aug 9, 2011.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    OK maybe it is the angle of the camera that gave me the illusion that it was only the top cover (as opposed to the entire battery) that's showing in the picture.
  2. R-P
    R-P Active Member
    808
    288
    Netherlands
    OK, now I see what you're getting at. It's the angle of the camera: it's the entire battery with the rubber caps still on (and sucked a little vacuum).
  3. 2009Prius
    2,705
    512
    63
    Did you find all of the caps maintained vacuum? I found my caps quite loose and only two of them held vacuum.
  4. Patrick Wong
    18,210
    6,517
    The GS Yuasa translucent case battery has a smaller capacity as compared to the black case battery. The latter is used on Smart Entry / Smart Start-equipped vehicles.
  5. R-P
    R-P Active Member
    808
    288
    Netherlands
    Which mine doesn't have, so that makes sense :D
    As for the caps being vacuum: depending on state of charge the chambers within a battery can have an over or underpressure. Or at least I remember reading something like this somewhere. In other words: don't worry. If really going deep into the matter, their bulging or dipping might give a hint as to what state one cell is compared to the other, but mine were all 'vacuum' regardless of the fact some had a 'water'-level under and some over the plates.
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    When I pulled the caps off my battery a few days ago some of the cells felt like they had a bit of a vacuum and some didn't. The clear plastic plate that fits over the caps is fairly snug to the top of the caps, so it should prevent any caps popping off if there is a slight over pressure.
    BTW. My battery was fully opaque black despite my Prius being non SKS. That may be a regional difference though (Australian model).
  7. 2009Prius
    2,705
    512
    63
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The caps on the battery are designed to vent to the chamber above, where the hose is connected. The label is what seals the plastic piece that goes over the caps. The caps could hold a vacuum but not pressure.
    As Patrick stated, there are two batteries used. The clear plastic case one is the smaller battery and the black case one is the larger one. I -think- later cars only came with the larger battery.
    2 people like this.
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Thank for the info David. I was wondering where the vent pipe connected to. I just had it (the battery) out a few days ago but didn't look closely enough to notice that.
  10. uart
    uart Senior Member
    4,220
    1,212
    Australia
    My guess is that if there was a significant amount of dried out mat to begin with, then adding water could have improved things by decreasing the battery's internal resistance. If however there wasn't any dried out mat then adding water would just dilute the acid and could slightly reduce the batteries performance.
    A slight dilution of the acid is not necessarily a problem. When electrolyte is lost from a battery it's usually through bubbling off of hydrogen and oxygen gas, so really only water is lost and the acid gets more concentrated. When you add back the water it's ideally just bringing the acid back to it's original concentration. If you added back too much water (like perhaps I did) then you could end up with a lower concentration than the original specifications. This could slightly decrease the battery's performance, but I doubt it would be very significant.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I solved the battery drain problem by disconnecting the door and hatch light, I do not use the courtesy light at all. ie: no more 12 V problems. :D:
  12. David Beale
    5,963
    1,989
    Edmonton Alberta
    Well, it's been a while since I last reported, and the battery is still doing fine. I'm now stressing it a bit more as my Amateur radio installation no longer automatically disconnects when I shut off the car. I set the radio to shut off after one hour (the timer starts when the radio is turned on). It draws about an amp on standby, which is typical for VHF/UHF dual band radios (this one is a Kenwood D-710 which is being used for APRS as well as scanning the local repeaters). If you go to aprs.fi and search for va6dab you can monitor my movements and make sure I don't speed. ;)
    It appears to me the reason most Prius batteries die early is they run out of water. I guess I'll be replacing this one either this or next year, as I've never seen a vehicular lead acid battery last longer than about 6 years in this climate. At least I got another year out of it and learned something by doing the add water routine.
  13. PeterPrius2007
    PeterPrius2007 Junior Member
    47
    Kitchener
    I can confirm this really works. I recently bought a 2007 with a battery that couldn't keep a charge. Car has 283,000 kms and it might be the original battery for all I know. Did exactly what OP said to do with battery and the Prius has been starting fine when before it needed a boost anytime it had been sitting for I think half a day or more. When I opened up the 6 tubes, I could see no evidence of water. Pretty amazing that it seems to have been fully restored by 97 cents for a bottle of distilled water!
  14. 2005pluginhybrid
    51
    25
    vancouver
    I have a 2005 prius and I have replaced the battery with 4 6 volt NIMH modules from a Ford escape hybrid.
    I configured the battery as 2parallel and 2 serial. Each module is 5 NIMH D cells at 5.5AH. So I have a 12 Volt 11AH NIMH battery.
    I had to extend the wires and place the battery in the tire well area.
    If I start the car regularly it all works fine. If it sits for a while, I have to charge the battery before driving.
    This is mainly due to the self discharge of the NIMH and some load from the Prius.
    If I was to put a .5 amp trickle charger on it I would not need to worry about sitting for a while(still on the list to do).
    I try to not use lead acid technology if I can.
    Oh and the NIMH cells are from a 2005 ford escape. Still providing a full 5.5 AH each.
