Some Prius Accessories in JP
Discussion in 'Gen 2 Prius Accessories & Modifications' started by NiMHpwr, Nov 30, 2004.
  1. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    I wanted to chime in the I want a set of the door alum kick panels. What would those run?
  2. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Is the first thing on this page (http://toyota.jp/prius/dop/function/index.html ) a factory DC to AC inverter? If it is, that's pretty cool. Is Japanese power compatible with US (same frequency/voltage)?
    Does anyone know what 2, 3, 5, and 6 (counting down the left column first, then the right column second) are?
  3. techogurl
    226
    Fayetteville, AR
    Ok... I asked in another thread once but this one is more active. Can the Japan center unit be replaced into an American unit? I am interested in the stock Mini Disc drive.
  4. SanZan
    SanZan Junior Member
    68
    Japan
    ryogajyc hope this helps
    Accessories on left side
    100V AC (100W max) Power Outlet (with Battery Protector) 12,600 yen
    Corner Sensors (4 Voice Sensors) 40,950 yen
    With warning lamps and voice warning
    Corner Sensors (Rear Left/Right only) 27,300 yen
    With warning sound
    Reverse Tilting Mirror
    Passenger side door mirro automatically tilts downward when shift moved to “R†12,600 yen
    Accessories on right side
    Anti-bacterial/Minus Ion Air Filter
    Improves cabin air quality, removes pollen, dust, cigarette smoke
    Filter lasts 6 months
    38,850 yen
    Corner Sensor (Front left/right only) 27,300 yen
    With warning sound
    Auto Antiglare Rear Mirror
    Automatically dims to prevent glare from tailgaters 15,750 yen
    Auto Retractable Door Mirrors
    Door Mirrors retract automatically when car is locked 10,500 yen
    The frequency of AC Japanese power is 50 or 60Hz depending on the "east" or "west" Japan. Many appliances don't mind, but the clocks in electronic equipment can run slow as a result.
  5. TxOllie
    TxOllie New Member
    Houston, TX
  6. Tideland Prius
    16,680
    I love those scuff plates but I just can't justify the cost.
    You can get those lights from a Scion dealer or make your own from computer lights :D
    That's cargo liner looks good. Even has raised edges.
  7. ryogajyc
    985
    165
    Reseda, CA
    Thanks SanZan,
    I'm interested in the A/C inverter, but I'm still worried about the incompatibility. I'm actually very surprised that Japan has _two_ A/C standards. It seems like it would make a mess of things (I guess it's pretty tolerable the way you explain it). Do they design things like the Prius A/C inverter to be configurable to either 60 or 50 Hz?
    Also, I read on Wikipedia that Japan uses plugs which have blades the same size, but the Japan Prius Website shows the plug is keyed...
  8. Neal
    Neal New Member
    San Clemente, CA
    Speedracer - Get me a quote on the leather steering wheel.
    Thanks,
    Neal Moen
  9. smasho
    smasho New Member
    44
    Oregon
    Good stuff!
    I'd suggest forgetting about the inverter. The problem is that it is 100 volts. That's brownout quality power in North America and would stress a lot of items. Also, 100 watts is pretty anemic. Name brand plug into the cigarette lighter inverters can be had dirt cheap. (I found a 375w TrippLite for under $50)
    Now the electrochromatic mirror without all the homelink buttons.......nice
  10. ryogajyc
    985
    165
    Reseda, CA
    I didn't realize it was 100 volts, but doing a quick google confirms that. That certainly is a deal-breaker. I didn't really need it anyways, I just kind of wanted it cause it was a neat accessory. The entire point would be to not have to carry around one of the 12V accessory outlet inverters anyways, of which I already own a 75W one.
    I'm not sure what you really need where 100W is counsidered anemic. Short of running an incandescent light bulb or a desktop computer, 100W or even 75W for that matter is fine for laptops, charging PDAs/cell phones, portable DVD players, etc. Keep in mind that while a 375W inverter sounds nice, you are actually limited to 180W due to the 15A fuse for the accessory outlets.
  11. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    You could get the full power by connecting it directly to the battery. DC/DC converter would recoup the current draw just fine.
  12. Speedracer
    Speedracer New Member
    378
    Nagoya, Shanghai
    I'm try to get price and also other thinks as well
  13. techogurl
    226
    Fayetteville, AR
    Can you see if there would be enough interest in the alum kick panels for a group buy?
  14. NiMHpwr
    NiMHpwr New Member
    70
    San Jose, CA
    I am interested in the leather steering wheel too. I got a rough quote from an upholstery shop and they said it would cost about $1g to have it wrapped posts and all not a wheel skins over. Mainly because they had to make a template and fit it from scratch.
    It would be awesom if we can get a factory wheel from Japan.
  15. Neal
    Neal New Member
    San Clemente, CA
    I got a price from japanparts.com on the steering wheel. E-mail me at [email protected]...
