Someone do a poll, noises and where built?
Discussion in 'Gen 3 Prius Main Forum' started by sshaw10, Oct 20, 2009.
  1. schoolchef
    schoolchef New Member
    30
    western MA
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Good point, I almost always drive alone and hadn't even thought of that. Next time someone is in the car with me I'll find a rough patch of road and check it out.
    I just posted some information on a "Front Seat Squeak Noise" TSB in the other rattle thread in case anyone is interested, post #68.
    http://priuschat.com/forums/gen-iii...o-you-hear-rattling-noises-7.html#post1000491
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Everyone may want to check the heater covering under the Glovebox area. Mine was as loose as a goose! I was shocked but an easy fix!
  4. JeffA
    JeffA "The Batmobile"
    23
    Northern California
    I have a "0" with minor rattles. They mosty eminate from the glove box doors and the center console as many have reported. I have found that both the upper and lower glove box doors are loose and when I apply pressure the noises go away. As for the center console, there is a thin line that runs the length of the console where the two pieces are joined. I've found that if I apply pressure directly to the joint that the noise subsides. I think felt might be the answer to most of the problems, I just need to do some disassembly. In addition, and I haven't read where anyone else has had this issue, but with the JBL sound system at higher volumes, I get both a intermittent pop from the front drivers side dash speaker, and the bass rattles everything else in the car...I guess I must have to minimize bumpin' my tunes at excessive levels.
  5. mwetter
    mwetter Junior Member
    Utah
    I have a 0 bot the end of June. There are a few rattles, but nothing as annoying as there seems to be with some.
  6. gil
    gil Junior Member
    83
    Richmond, VA
    Ours is a "0" purchased at the end of July, and so far so good. Only heard a squeak once, but will wait till it gets really cold to see what happens. Our 05 Prius had squeaks to entire time we owned it, but they were worse when cold. Most of them were around the small fillers between the forward side windows and the dash. I haven't heard this on the new one as these fillers appear to be coated with a felt material.
