something is wrong with my regen system
Discussion in 'Generation 1 Prius Discussion' started by krystalstorm, Oct 15, 2015.
  1. krystalstorm
    krystalstorm Junior Member
    coatesville pa
    took my gen 1 to a mechanic to have the front ball bearing replaced, now the abs light is on and in over three hours of driving i only got one half regen symbol. i used to get atleast one every 5 minutes. what did he do wrong? update; the rest of the hybrid system charging system works fine. just no friction braking regeneration.
    #1 krystalstorm, Oct 15, 2015
  2. usnavystgc
    3,159
    988
    Tucson, AZ
    Your wheel sensor likely came unplugged or was unplugged. This tells the system if the wheel is spinning or not so it can adjust the ABS and may affect regen.
    fotomoto likes this.
  3. krystalstorm
    coatesville pa
    you are were absolutely correct, i went back and made them look again, the sensor was not push in far enough. car is fine now. thx
    usnavystgc likes this.
  4. usnavystgc
    3,159
    988
    Tucson, AZ
    Great. Glad I could help someone today. :)
    bwilson4web likes this.
