Something wrong with my Prius? :(
Discussion in 'Gen 2 Prius Main Forum' started by Dolce_Vita, Apr 20, 2011.
  1. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    Hi :)
    I'm possibly being paranoid, but twice, after hard driving, my Prius has smelt strongly of burnt plastic/rubber.
    The first time was when i was driving to the mountains on some VERY steep roads which no required full throttle acceleration. Upon arrival at the top, i got out and a strong burnt rubber smell was in the air.
    The second time i had 3 friends in the car and was again going on hilly, fast paced roads with relatively strong acceleration required. Upon arrival at the destination, everyone noticed the same smell i noticed last time.
    Neither time was i driving dangerously fast (below 45-50mph), yet the ICE was working relatively hard and for over an hour. Is this normal, has anyone experienced it, or should i be worried?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    That's normal. I use to get it with my 2004 and also get it with my 2009 when climbing a steep hill.
  3. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    I have done hills to mountains many times in South California, sometimes even with 4 good sized people but never felt that. Smell of rubber implies tires? Is it rubbing? What size tires you have?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Mine makes a hot sort of smell sometimes. It's almost always on the highway at speed. I suspect you are getting a smell from the hybrid battery vent. Hobbit did a good job describing this in one of his posts.
    Tom
  5. macmaster05
    macmaster05 Senor Member
    4,050
    728
    It may even be a smell from outside, nothing whatsoever to do with your car. I know that's happened to me a few times.
  6. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
  7. macmaster05
    4,050
    728
    ^I dont need to explain anything to you. Shitttttt.....
    One time I thought I smelled my fog/headlight wires melting but incidently I was driving past a junkyard. I knew because the next day I smelt the same thing but my lights weren't even on.
  8. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    Sorry guys, i should have been more specific. It's noticeable when stepping out of the car. It's a kind of burnt rubber/generic burnt smell to be specific, although my tyres couldn't be rubbing as i have the OEM wheels/tyres on the car?
  9. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    That same thing happened to me with my other car. Turned out to be the flux capacitor.
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Could it be the traction battery heating up? Maybe you smell it because the fan kicked in?
    I've only smelled it once and that was while following my friend's Prius down a very steep slope leaving Yosemite down the eastern side of the Sierra Nevada.
  11. Avshalom
    Avshalom New Member
    Los Angeles
    I've seen plastic bags get stuck to exhaust systems several times. Once you heat up the exhaust it starts to melt and smell.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Never smelled anything like that on my 07. Thats not good though
    as something is def overheating. I would be very concerned personally.
    Next time open the hood and smell around. Pull the dipstick and check that. Smell in the back of the engine as that's where the exhaust is. Maybe its the cat converter overheating? Easiest place to check is the back of the engine by the firewall.
    Whats the mileage?
    Hows the engine oil maintenence?
    Transmission fluid maintenance? If your pushing the car that hard with a full load you should make sure you have fresh trans fluid.
    That heavy load is very hard on the electric motors in the trans.
    The trans is our cars are very very expensive to replace and there is no repair. And very cheaply & easily maintained.
    And lastly like another poster mentioned smell the hybrid battery vent. Its in the backseat on the passenger side right where a passengers elbow would be. There's a little vent there. And there's a fan behind that vent. Next time see if you can hear a fan in that vent hole turn on which means the hybrid battery has overheated from the high output low charge load. Many posters have mentioned that scenario in a hilly high load event. Must be hard on the traction battery though.
    Good luck with your nose!
  13. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    My Prius has 45,000km / 28,000 miles, it's a November 2008 model.
    Maintenance wise, i personally do nothing, i just take it to Toyota whenever they tell me a service is due (every 10,000km i think it is?), so i dont really knwo how the oil & trans fluid is going. Although i do hear the battery fan coming on relatively often, especially when the car has been parked in hot sun, i usually open the window next to the vent to channel air into that side of the car.
    I'll take the car for a drive later this afternoon, i'll include some full throttle acceleration and hills, then sniff the engine, battery vent (hahah)
    I'm actually really worried now :(
  14. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Don't be worried....your just driving with heavy load on hills which tends to push a battery assisted car to the max. If it was me I would push up my maintenance to protect your car.
    Use full synthetic motor oil. You must ask for it at the dealer.
    Change that every 5,000 miles.
    Change the trans fluid every 30,000 miles. I do. Seen many many different dealer quotes ranging from $125 to $200. Shop around.
    Its a smart thing to do.
    And don't drive with the windows down. Opening that window by that fan will not help.
    You have a very nice ac system with a filter on re-circulate that uses very little energy to run compared to a normal car. Its electric. It will clean & condition the air and keep the inside of the car dry preventing premature corrosion of the hundreds of electrical connections in the cabin especially on the many hybrid battery terminals inside the hybrid battery box which you are putting a heavy stress on already.
    Plus it will assist in keeping the battery cool. That fan is coming on because the battery is heating up under load.
    You should not hear that fan come on if you are parked in the sun. I live in Fla and my parked car see's blistering sun and I have never heard that fan come on. Thats very strange. I have owned my 07 since new and have never heard that fan come on.
    Also keep that little battery vent clean and clear of obstructions especially if you have passengers back there. Keep the interior of the car dry & cool. It costs next to nothing.
    Good Luck!
  15. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Which way does the fan direct air ? I presumed it was cabin -> battery.
  16. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    I pretty much never use the air con, only windows down as i dont really like the constant cold air the aircon produces as it makes me constantly sneeze (weird, i know). Sorry, i meant the fan will turn on once the car is started, the first time it happened was on a 118degree F day, but generally on days over 95 degrees the fan comes on whilst driving.
    Do dealers change the trans fluid as part of the servicing regime? i have another 4 years warranty on the car, so i'd assume they'd change it at some stage?
  17. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    Additionally, i was driving into a roundabout a few weeks back, and i went onto the throttle fairly lightly, yet the car just wouldnt move at all, initially i though it was traction control, but the car eventually drove with no issues, it just seemed to stall for a second. It felt similar to the hesitation Automated Manual gearboxes experience :s
    I think i'll sell my Prius soon, it's a great car but i want a manual car :(
  18. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    I think it's mainly your battery cooling system. I sometimes got that smell if the fan was working hard.
    Go out and sniff the battery vent, that's probably what your smelling.
  19. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I believe it is cabin too battery then out through the vent tubes that run across the 12v battery area to the outside.
  20. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    Okay, i just got back from a 20 minute drive, it was quite cool outside and i was hypermiling/driving softly. I sniffed the battery vent after the drive and it smelt very slightly of a plasticy, chemical smell, not the burnt smell i've experienced. If it was the battery, wouldn't the smell be strong inside the car as well? because i've only even smelled it outside of the car, not inside :s
