Soon to be Prius owner (Ontario Canada) - Questions!
Discussion in 'Gen 2 Prius Main Forum' started by fatale, Jul 6, 2006.
  1. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(fatale @ Jul 6 2006, 04:32 PM) [snapback]282262[/snapback]</div> thank you for posting the link and a copy of the form and instructions. Now others doing a search can find it. Good on you! for both getting a Prius and the post for the rebate.
  2. fatale
    fatale New Member
    28
    Toronto, Canada.
    <div class='quotetop'>QUOTE(Frank Hudon @ Jul 6 2006, 11:11 PM) [snapback]282380[/snapback]</div>
    Crud. i just realized that is the OLD form. So call the # on it and find out where you can download the latest application. Im suprised that they have not pulled that one off the site.
  3. chuckieland
    chuckieland New Member
    25
  4. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(fatale @ Jul 8 2006, 07:13 PM) [snapback]283109[/snapback]</div>
    As far as I know, I think that is still the current form. The only part that has changed is earlier in the document where it indicates the limit is $1000, which Ontario has since doubled to $2000. However, this amount is not indicated anywhere on the form itself.
    I filled that form out and mailed it around early/mid May (need to check my records), so I should be receiving my rebate any day now... Will report back when I do!
    - Kevin
