Sorry I doubted you on affect of heat on MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by DumbMike, Sep 26, 2010.
  1. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I find that holding my breath helps in winter as the windshield doesn't fog up as much so I can keep the heater off.
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Tony,
    Very informative info display. Thanks.
    Can you offer any thoughts on why your FE/MPG's took the slide in 2009?
    It doesn't look to be temps related. :confused:
  3. ItsNotAboutTheMoney
    2,287
    460
    Maine
    We're 10% ethanol all year round here and winter mileage will suck.
    While the winter swing for the Prius isn't as great as mpg makes it seem, the Prius is affected more because the EV system is affected by temperature.
    It'd be interesting to see a mileage curve for a regular car. You should see a similar but gentler curve.
  4. ItsNotAboutTheMoney
    2,287
    460
    Maine
    Maybe it rained more.
  5. ItsNotAboutTheMoney
    2,287
    460
    Maine
    What a load of hyperbolics! ;)
    Don't suppose you have it or can produce it in gp100m? That should show the variation more realistically.
  6. ItsNotAboutTheMoney
    2,287
    460
    Maine
    Snow tires. With the Prius, as with any other car, good snows tires will make all the difference especially given the poor performance of the stock tires in the wet.
  7. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    At the end of 2008, I got new tires. I've had one person tell me that the reduced tread of the original tires meant that they were smaller and therefore rotated faster which skewed my mileage upward. Then the increased radius of the new tires provided a more realistic mileage. There are multiple reports of people getting new tires and seeing their mileage drop 3 - 5 mpg until the tires are broken in.
    I had to go back to the tank-to-tank notes to figure out the two dips in 2009. One I remember as an interstate trip to my home town and back (750 round trip, pure interstate). The first one, however, was a combination of highway miles driving home from Hybridfest and a mileage killing visit to the dealership.
    All records are here: http://www.chicagopriusgroup.com/MileageLogs/TonyPSchaefer/All.htm
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am playing with reasons it can get 'too hot'.
    The sending unit for outside air and for intake tract air are not calibrated, so may vary even if the air temp is really the same.
    1) the engine compartment may not be able to 'clear' the hot air generated. (I have no grill block yet)
    2) the aluminum intake runners may be being heated by the hot cylinder head
    http://www.outlawengineering.com/tech.html
    3) more intake air may be allowed back up into the runners
    4) the anti throttle plate freeze protection may be excessively effective
  9. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
  10. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    My max mileage occurs when the average outdoor temp is about 75-80. That's the daily average so that means it's about 65 at night and 90 during the day. It's warm enough to warm up the engine quickly but not too hot where the AC is on.
    Tony lives in a cooler climate and his mileage is max at his local peak temperature - but that is well below the peak we see here.
  11. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    2017 Prius Alpha
    But how do you feel about it?
    Grammar Girl : Affect vs. Effect
    Sorry, the psychologist in me just could not resist.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ lol.
    Mike, I would not read too much into mpg readings from a day or three. There are too many confounding variables. Wind, e.g. So while it is true in general that Prius mpg starts to decline as temps drop below 70F or so, the slope is very moderate until you hit under 40F unless the trip is short.
  13. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    IMO 1 mpg increase within a single tank in non-controlled conditions is statistically irrelevant. I vary several MPG from tank to tank seemingly while doing the same thing. It's just impossible to conclude anything from one MPG in the scenario outlined in first post.
  14. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I agree with you that 1 MPG is basically irrelevant. But if you do the math, I had to get about 62 MPG at the end of the tank in order to increase my 51 MPG for the first 9-10 gallons to 52 MPG on that final gallon. I think 62 MPG is fantastic. I wasn't driving anywhere different than normal. The only thing I could figure out was the excessive heat we were having.
    I could be wrong, and normally am wrong.
    Dumb Mike
