SOUND DEADENER from GTMAT
Discussion in 'Gen 3 Prius Audio and Electronics' started by kknguyen1168, Jun 12, 2012.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    I would like to install this for my Prius 2010 for 4 doors ,back seats, and in the back in the spare tires, anybody use this product yet or have any info about this product please let me know before I buy it. It cost 109.99 for 50 sp ft 80mm.
    V/r
    Khoi Nguyen
    858-699-7604
  2. lopgok
    lopgok Member
    177
    30
    unknown
    I am pretty happy with peel & seal. A roll that is 6 inches by 25 feet cost $16.00
    I did my front doors and they are much quieter than my rear doors.
    I am not sure that expensive deadening stuff is cost effective.
  3. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi
    I heard a lot about Peel&seal, how thick are they? do you get any smell at all? reason I ask because I plan to do in back of my Prius too?, why you did not do the rear door? did you upgrade your speaker at all or just install the Peel&seal just because the Road noise?
    V/r
    Khoi Nguyen
    PS: if you did upgrade your speaker, may I ask what the name of those speaker and the size? do you have JBL system?
  4. lopgok
    lopgok Member
    177
    30
    unknown
    Peel & seal is rougly 2mm thick. There is no smell.
    I have upgraded my front door speakers and my dash speakers.
    I put in kenwood kfc 1664S speakers in the doors, and
    pioneer ts a878 speakers in the dash.
    I have the base 2012 PiP stereo.
    Using the hole in the door where the speaker went, I was able to put in a layer of peel & seal covering about 2/3 of the door.
    I haven't gotten around to the rear doors yet. I plan on using the same kenwood speakers and more peel & seal.
    You might consider covering the clear plastic film on the inside of the door. It can be peeled off for maintenance, but I am sure it doesn't help the sound. Some folks screw thin plywood or metal over it, and then use some deadening over it. I am sure it sounds better than mine, but would be a big hassle to remove if maintenance is needed.
    The peel & seal reduced road noise a bit, but more importantly for me, it reduced the very tinny door sound.
    When I tap the outside of the front & rear doors the sound is totally different, and much deader on my front doors.
    The dash speakers are in parallel with the front door speakers.
    Since the dash speakers have a really small capacitor to only pass high frequency, I added a 100 uf non polarized cap in parallel to let much more low frequency through. Based on my calculations, it is roughly 3db down at 400hz now, since I put in the big capacitor,
    I added 2 ohm resistors in series with the door speakers and dash speakers to increase the impedance of the combined speakers to roughly 3 ohms plus wiring losses, so I don't cook the factory head unit.
  5. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
