Sound Deadening 2010
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Prius_Angie, Dec 19, 2018.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    OK. I just completed a sound deadening project for 5 doors to my 2010 Prius, to include rear hatch door. Very noticeably positive in now i can better hold car conversations, use phone, and listen to radio. The heat is better retained during the winter; i can only assume summer AC will equally be positive. I will provide a summer update if i get motivated to do the dash, flooring, and roof.
    - TIME. Project took <8 hours over 3 days.
    - MATERIALS. I used 2x different types of product to both deaden sound and absorb heat/cold: Home dept 1x roll of butyl-rubber tape (mainly used for roof flashing) and 2x rolls of Frost King fiberglass insulation
    - i used loads of antibacterial wipes to clean the metal door interiors
    - destroyed all the old vapor barriers an replaced with butyl-rubber tape
    P_20181217_125954.jpg P_20181209_162411.jpg P_20181209_162356.jpg P_20181209_162403.jpg P_20181217_123820.jpg P_20181217_123807.jpg P_20181212_165244.jpg P_20181212_170113.jpg P_20181219_123440.jpg P_20181219_123613.jpg P_20181219_123726.jpg
    I also took the added time to push out and stabilize with zip ties, the broken arm rests on 3:4 doors.Not fashionable but highly functional.
    RMB, bisco, PriusCamper and 1 other person like this.
    52,878
    well done, and a great write up, thank you!(y)
    Prius_Angie likes this.
  3. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Nicely done sir, nicely done.
  4. Prius_Angie
    245
    229
    Saint Louis
    i recently drove in a friend's 2013 Prius for comparison, we both agree the sound deadening project noticeably quieted the car interior
    Very cold now in St Louis now
    when weather clears up
    I will perform the same sound deadening treatment to my 2005 Prius, as well
  5. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Any db readings?
  6. Prius_Angie
    245
    229
    Saint Louis
    douglasjre,
    Sorry I never really invested in a mic tool to scientifically perform this procedure.
    cheers.
  7. douglasjre
    2,250
    751
    Null, NL
  8. Prius_Angie
    245
    229
    Saint Louis
  9. Prius_Angie
    245
    229
    Saint Louis
    OK, i have conducted a sound meter test, late after my sound deadening procedure. Too bad i didn't do a BEFORE, but anyone watching can at least test out their car for a baseline and decide for any interest in conducting this procedure
    - i conducted 2x tests at 70mph on hwy (look to the last 2x test samples, as the top ones reflect my 2005 Prius)
    - 41 MIN / 68 AVG / 77 MAX
    - good to see that both 2005 & 2010 procedures (4x doors and back life gate) produced the same sound deadening results
    Sound Meter - Apps on Google Play
    #9 Prius_Angie, Jan 11, 2019
    Coots and SFO like this.
