Sound deadening: road noise control
Discussion in 'Prius c Accessories and Modifications' started by Ronan, Aug 5, 2016.
  1. Ronan
    Ronan Junior Member
    28
    Denver Co
    2014 Prius c
    I know many sound deadeners are just heavy, which would hurt the gas mileage. But has anyone done anything with a lighter weight deadener or something to help cut back on the in cabin road noise? If there is a thread out there on this already for the C, please point me in the right direction.
  2. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    I added some of this to the C and to the Gen II Prius, the Gen II had a door rattle driving us crazy, and the C; well you know it is a bit loud with certain road conditions.
    30SQFT Five Door Kit 12"x36" Sheets Gtmat Pro 50mil Car Sound Deadener Material | eBay
    I also added the foam one in the C doors... Has not affected mileage.
    kenoarto and Ronan like this.
  3. lifehouse
    lifehouse Junior Member
    92
    GA
    Heard over about Dynamat, see if it will be feasible.
  4. Ronan
    Ronan Junior Member
    28
    Denver Co
    2014 Prius c
    Yeah Dynamat but you gotta watch out for the heavy rubber types, I thought someone may have already investigated a lightweight sound insulation. I'll have to look around.
  5. Hyper Hybrid
    Hyper Hybrid New Member
    22
    Gig Harbor, WA
    Check out Summit Racing's house brand sound deadening. It is supposed to be as good as Dynamite, but much cheaper.
  6. bisco
    52,738
    check with @edthefox5 , he used a lightweight sound deadener very effectively.
  7. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    I can't speak for the Prius C, but I used 50 mil Noico in my 2nd gen for good results - outside and wind noise were significantly reduced. However there's still a lot of noise coming through from the suspension and wheel wells. Definitely helped, but my next upgrade is to get quieter tires. With such low cost options now available, Dynamat is way overpriced IMHO.
    If you want to treat all 4 doors with about 75%, you can get this kit:
    Noico 50 mil 25 sq ft.
    It comes with 12 sheets, so you can use 3 per door, or you might get better results using 3.5 in the front doors and 2.5 in the back. I believe it's only 11 lbs.
    If you want even better sound treatment for a bit more $, you can get this kit with thicker layers and enough to treat your doors and tunk area:
    Noico 80 mil 36 sq ft.
    Also one trick that I did is to seal in the inside of my car doors by cutting out shapes of 3/8" hardboard and fitting them to the large holes on the inside sheet metal. Doing this you can form a (nearly) sealed enclosure on the inside of your doors, which will add another layer for blocking sound. This will also improve the bass response of the door speakers, and improve insulation of the car reducing A/C load slightly. See picture:
  8. bisco
    52,738
    wow! that's a great job kevin.(y)
    Kevin_Denver likes this.
  9. hayashi
    hayashi Junior Member
    socal
    #9 hayashi, Aug 22, 2016
