Sound levels inside car using EV vs HV modes
Discussion in 'Prime Main Forum (2017-2022)' started by EazyPeazy, Jan 19, 2019.
  1. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Just for curiosity sake, I downloaded a free decibel app for my phone and checked how loud the EV sound was in comparison to HV sound. Suffice it to say, EV mode was significantly quieter as you would imagine. Sound in decibels ranges from 60 dcb at 25 mph to 67 dcb at 60 mph. I viewed a YouTube video testing Tesla Model S in same speeds ranges from 62 - 67/68 at same speeds. The model 3 readings were slightly higher. HV mode significantly louder sadly when pushing car to accelerate - 80+ dcb. So pretty impressive sound deadening on EV mode.
  2. gene
    gene Member
    100
    NH
    I was wondering about this, especially since some of the Prime reviews mentioned "road noise" being one of the "cons." Sounds like the Prime is actually pretty good... in EV mode. Thanks!
    EazyPeazy likes this.
    52,774
    tires and asphalt type make a difference as well
    mr88cet, Tideland Prius and EazyPeazy like this.
  4. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Yes, in the case of our P.Prime, drive-train sound is minuscule compared to that of the Bridgestone Ecopia Plus tires.
    Those tires are amazingly fuel-efficient — EV or HV. However, they play road-surface texture like a phonograph needle! On a smooth road surface, they and the entire car in EV mode especially, is very quiet, but get it out on a rough road surface, and it sounds pretty raucous!
  5. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Doesn’t handle bumps well, for sure.
  6. bisco
    52,774
    especially when following recommendations to over inflate
  7. mr88cet
    2,313
    1,335
    Austin, TX
    In terms of cushioning bumps, I’d say they’re “decent.” I find the P.Prime’s suspension to be smoother than our 2009 Prius’ suspension. I imagine that the battery in the rear adds a little inertia — resistance to up/down motion.
    Blauer Glimmer likes this.
