Sound while driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robl45, Apr 29, 2018.
  1. robl45
    robl45 Member
    137
    I seem to have some sound while driving, kind of seems like tire noise but is vibrating a little as well. it appears to be noticeable from 45mph on up. I took a video but I don't think you can really hear anything. It doesn't appear to be the sound of a bad wheel bearing. Any ideas on what it could be?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Some questions;):
    • How old are your tires?
    • Have they been checked for imbalance recently?
    • How many miles on your Prius?
    • Why can’t it be a wheel bearing?
    Keep us posted (y).
    SFO and bisco like this.
    52,854
    how many miles on the car and the tires?
    does the sound change if you rotate them?
    does the sound change with speed?
    does the sound change when turning?
    Raytheeagle likes this.
  4. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Didn’t mean to steal your thunder ;).
  5. robl45
    robl45 Member
    137
    150000 about. I have not tried to rotate them, I will need new tires shortly so I am getting them replaced soon. No it does not seem to change while turning. Nor does it really seem to change with the speed. I mean it gets a little more pronounced when I'm going 80 versus 45 but not too much different.
  6. bisco
    52,854
    no prob, great minds and small minds sometimes think alike.:oops:
  7. bisco
    52,854
    how long have you owned her, and how long has it been happening?
    has it gotten worse?
    i think you need to eliminate the tyres first.
  8. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    How are your brakes? Last time they were inspected? Could it be the sqweeler for low pads?
  9. robl45
    robl45 Member
    137
    I've owned a year and a half. Just noticed yesterday
  10. robl45
    robl45 Member
    137
    So you guys think it could just be the tires? I was just worried about wheel bearing or something, but it definitely is not making any weird noises when I turn the wheel or anything.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’m not sure about that ;).
    In post #2 I asked why it can’t be:whistle:.
    An inspection of the wheel and associated components will help determine the next steps :).
    Keep us posted (y).
  12. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    A bad wheel bearing would begin around 40mph and at certain speeds be very loud, a vibration would also vary a bit with speeds, is it the steering wheel (front wheel) or do you feel it in your seat(rear wheel), now consider a bad tire and wheel bearing.
    A tire making noise should be visually evident, separated tread, loose tread, etc.
  13. padroo
    padroo Senior Member
    2,763
    2,253
    Try lifting the front of the car with both front wheels off of the ground and see if you can hear it that way. It will eliminate the front tires and the rest of the drivetraine. Do it safely. It really works great when the engine is off and everything is spinning by the electric motor.
  14. robl45
    robl45 Member
    137
    It appears to be around 40 or so. I just feel a faint vibration and a whirring noise. It appears like it is coming from one of the back wheels. It is not loud per say, more like a windnoise type of noise that stays relatively constant but the vibration starts to increase a bit as the miles per hour go up.
  15. padroo
    2,763
    2,253
    After a long fast drive check your wheel bearings for temperature by carefully feeling the back side of the hub.
    One of those temperature guns would be best.
  16. robl45
    robl45 Member
    137
    Don't have one of those. I drive 55 miles each way. I don't think i"ve ever heard it before. The tires aren't in the best shape for sure, I just don't want a wheel bearing going out on me while on the highway.
  17. bisco
    52,854
    they usually get very noisy before they go.
