Sounds like clicking noise from the engine
Discussion in 'Gen 3 Prius Technical Discussion' started by tkersey, Apr 2, 2012.
  1. tkersey
    tkersey New Member
    Phoenx
    When I accelerate, particularly between the 50-60 mph range, the engine makes a very subtle, yet definite clicking noise. Mentioned this to the dealer - the car is still under warranty - and of course, they can't replicate the sound..is this common? Any one else experiencing this?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I trust you've checked your oil level?
    Failing that, is the a/c on - is it the a/c relay?
    Trust there are no nails in your tyres.
    Is a twig or small branch stuck under the car
    Is the plastic under tray (under the car) come loose if you've driven through a flood or large puddle? If they come loose they can flap about at 50 mph.
    Anyone else any ideas?
  3. tkersey
    tkersey New Member
    Phoenx
    Yep, looked at the obvious...
    Although I've not looked at the tray..I'll do that today! I'll follow up with the A/C relay, since we use the A/C a lot in AZ!
    Thanks!
    QUOTE=GrumpyCabbie;1514275]I trust you've checked your oil level?
    Anyone else any ideas?[/QUOTE]
  4. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    How far a part is the clicking, is it once a second, fifty times?
  5. tkersey
    tkersey New Member
    Phoenx
    More like every second, until the speed gets up or around 55+, then it stops...strange..
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    A leaf stuck in the a/c fan? Brake pump? Front passenger side seat belt tapping against the plastic side panel?
  7. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    It sound like an injector going bad, dealer should see it on a scope.
  8. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    I'm glad you brought this up. I just developed a similar (maybe the same) noise over the past two/three weeks. Mine is between 20 - 30 mph when I leave the house in the morning and go up a slight grade. Sounds like a loose bolt in the engine area that is vibrating. I'm trying to capture it on my phone and will post if and when I'm able too. I did have the TSB for the engine knocking done not too long ago and I'm wondering if there is a bolt that worked a little loose?
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Sounds like you answered your own question.
    Or is this a sound applicable only to those with new replacement manifolds?
  10. Unlimited_MPG
    218
    24
    Federal Way, WA
    Good question. I would be interested to hear if the OP had the TSB / manifold replaced.
  11. tkersey
    tkersey New Member
    Phoenx
    I've had mine to the dealer twice. I'm even wondering if they are driving it to try and hear the noise! They say the diagnostics don't show anything wrong, but, that noise is certainly not normal. Definitely coming from under the hood! No issues with acceleration, but I can just see it...the day the warranty runs out, then whatever it is really craps out...maybe I need to try another dealer??
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    That is the standard line. I would ask to have the shop foreman take a drive with you. If that does not work, find the Toyota Customer Representative at the dealership. Yes... there is such a thing. Made a big difference in getting my issues dealt with!
  13. Unlimited_MPG
    218
    24
    Federal Way, WA
    Here is a short video that captures the rattle noise I hear coming from my engine area (hope you can hear it). Not sure if this is the same noise the OP was hearing or not? Mine is at about ~25 seconds into the video. Going 20 -30 mph up a slight grade. Seems to only happen when engine is cold (no warm up) and going up a slight grade. Happens nearly every morning on my way to work.
    [ame=http://www.youtube.com/watch?v=PX-19btKSdw&list=UUtDg-YepVr_pQDcc6qnUCFA&index=1&feature=plcp]2011 Prius Unknown Rattle Noise - YouTube[/ame]
  14. jaredy
    jaredy Member
    162
    SoCal
    I have experienced this when I drove a rental Prius and my own Prius. I would think it is normal, but I really did checked my trunk because I thought it was from my trunk. :confused: Conclusion, we have good ears.
  15. musarc
    musarc New Member
    Mechanic told me the clicking sound is an indication that the 12V battery about to go. You might want to get that checked.
  16. seegarman
    seegarman Junior Member
    49
    Seattle
    I'm getting the same clicking noises too, when the engine is cold and upon slow acceleration. The noise goes away soon after the engine warms up.
    I have not had the engine knock TSB done so everything is factory installed. My guess is either valve train rattle or piston slap (similar to Chevy Tahoes)?
    I'm going to wait and see if it gets worse before I go to the dealer.
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Interesting... never heard this in my car. Had both T-SBs done related to the engine just recently but never heard this prior to that.
  18. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Which oil do they use in Alaska? Is it 5w30 like in Canada?
    Maybe the thinner 0w20 oil can cause this? I remember my car ran quieter when 5w30 was used by mistake one time.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    0W-20 GC... just like the rest of the states. That is probably better up here anyway with the colder temps.
    Just from listening to the video, it should like the noise if coming from the inside of at the most up against the firewall. Could also be the hood prop...
  20. Unlimited_MPG
    218
    24
    Federal Way, WA
    I'm going in Saturday morning for my 15k maintenance. I mentioned it to the service department in the notes when I scheduled the appointment online. I have the video and I'll see what they say the noise is. I should have an update tomorrow.
