Sounds like clicking noise from the engine
Discussion in 'Gen 3 Prius Technical Discussion' started by tkersey, Apr 2, 2012.
  1. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    UPDATE: I went in this morning showed the Tech my video. Tech has now ordered parts for T-SB-0204-11 (Vibration from Engine after Cold Soak). He believes this might fix the issue. Once I have this done I'll report back if it does fix the issue.
  2. studioRS
    studioRS Junior Member
    23
    Northern Vermont
    Our 2011 does the same exact noise. I don't think is is a mechanical noise but, more like a loud electric noise. I'm going to equate it to almost like a relay going on/off very quickly located somewhere deep inside the dash area. Seems to only happen on certain throttle input levels, almost like when you float the throttle. Happens less when it is in cruise control but, definitely sounds like a relay going toggling on/off quickly.
  3. Unlimited_MPG
    218
    24
    Federal Way, WA
    UPDATE: had the engine mount TSB done today and it didn't eliminate clicking noise (what I believe is coming from the engine area). Happen right as I accelerated out of the dealership driveway. I think it may be the same noise others are posting about coming from the front fender area? I might try some of the advice from other poster on that issue and see what happens..
  4. Jeff D
    Jeff D New Member
  5. Jeff D
    Jeff D New Member
    Have the same issue. Prius 2012. At 5000 miles, started to get a rattle from the dashboard area when accelerating from 30 to 50 mph. Something seems to be vibrating. Have appointment with dealer. Saw a reference to a Tech Service Bulletin concerning replacing fender clips to eliminate a similar sound. Maybe that is it?
