Sourced (Harbor Freight - $9): 17mm thin wrench for front brakes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pmike, Oct 25, 2021.
  1. pmike
    pmike Member
    237
    81
    Central Florida
    Replaced the front brake pads yesterday and didn't want to delay the job ordering a cone/thin wrench and didn't want to grind down my good tools. Figure the Harbor Freight wrenches might be thinner than my Craftsman (they are) or I would be fine with grinding down these cheap wrenches ($9). The 17mm was just barely able to slide on without modification with a little wiggling.
    2013 Prius Two original owner in Florida with almost 125k miles, all original brake components minus the brake booster components covered under the extended warranty. Outside pads were down to wear indicators, inside pads had probably 50% left on both sides. Would seem to indicate that sliding pins need to be lubed between pad changes to get the full life out of them.
    #1 pmike, Oct 25, 2021
    privilege likes this.
  2. Mendel Leisk
    42,048
    Soon after we bought our 2010, I was wandering 'round in Princess Auto up here, spotted a slim 17 mm. Just a mm or so less than one I already had, but slim enough. :)
    Funny thing is: even if you don't restrain the boot with a 17 mm, it doesn't rotate much, when you're breaking that bolt (going into slide pin) loose. And you pretty much need 3 hands to use it while loosening or torquing the bolt.
    But yeah, they're out there; you don't have to use a sheet metal bicycle wrench.
    #2 Mendel Leisk, Oct 25, 2021
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  4. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    fuzzy1 likes this.
  6. Mendel Leisk
    42,048
    I've got a couple of 17mm wrenches.
    The thicker one, which I've had for years, checked with a caliper, is a smidge over 8 mm, not even 8.1. It does not fit.
    The thinner one, which I picked up while browsing at Princess Auto, is a similar smidge over 6 mm, and it just fits.
    That said: the construction of the caliper slide pin seems the same as Honda's I've dealt with for years, and Honda Shop Manuals say nothing about restraining the pin when breaking loose or tightening the bolt.
    Also, the few times I've opened up the brakes on our Prius, I've used the slim 17 mm wrench to restrain the pin sometimes, and some times I've forgotten. I may just "forget" more, because it's awkward, holding that extra wrench.
    xliderider likes this.
  7. fuzzy1
    10,603
    As one who has needed and gradually built up a broader set of bicycle tools, having multiple applications makes it easier to justify certain items.
    farmecologist and xliderider like this.
