Space in dash behind/around stock radio?
Discussion in 'Gen 3 Prius Audio and Electronics' started by trentofdestiny, Aug 13, 2016.
  1. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I am considering installing an Alpine KTP-445U power pack amp and was wondering if anyone else has done this. Reason I'm asking is, I would like to know where in the dash to hide it. I had no trouble hiding the front crossovers in the dash but this is a bit bigger. Hopefully I get some insight before 3pm when I go to tear everything apart :p
    iPhone ?
  2. CoolPrius
    CoolPrius Active Member
    218
    291
    86
    Virginia
    2018 Prius c
    I would do upper glove box if you want to keep it close. It's pretty tight back behind the radio and the lack of ventilation could be an issue. Good luck
    trentofdestiny likes this.
  3. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I did see a spot against the heater box and the roof of the lower compartment of the flying bridge console. Basically above where the lighter socket is
    iPhone ?
