Spacers question.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PutPutMobile, Jan 10, 2018.
  1. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    I’m looking for good quality spacers. My rear wheels are more tucked in due to the offset of +48 on my Weds.
    What kind of spacers do you recommend? Thanks in advance.
    9D5FD440-0AB9-49BD-B8B7-7D6DB24B4D07.jpeg EA0A1B6A-51D5-47B2-B135-B9C98C5E659C.jpeg A9E790E7-E3CD-477E-B1EC-05237308E592.jpeg
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
  3. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    H&R is quality stuff
    James Powers and PutPutMobile like this.
  4. PutPutMobile
    292
    518
    Buena Park, CA
    Thanks guys for the info.
  5. PutPutMobile
    292
    518
    Buena Park, CA
    I know there’s an old thread about cambers. But I’ve noticed my rear are negative and tilted inward after installing my weds looking it from the rear after I crouched down.
    Anyway are there any camber kits or bolts for the Gen 3? Or it can’t be adjusted?
  6. m3pare
    679
    1,818
    SoCal (626)
    I believe are camber bolts/plates for the front and camber plates/shims for the rear. Stock adjustments are very limited.
    PutPutMobile likes this.
  7. whiteonblackprius
    whiteonblackprius Active Member
    170
    244
    Los Angeles
    I got my Ichiba spacers from @ hybrid pit. 45000 miles on them
    James Powers likes this.
  8. PutPutMobile
    292
    518
    Buena Park, CA
    Thanks. That’s what I thought. I just wanted to straighten out the rear since it’s tilted and it might affect the inner thread.
  9. PutPutMobile
    292
    518
    Buena Park, CA
    No thanks. I don’t think I need spacers anymore since the bottom edge of the tires is almost aligned flush near my side fenders.
  10. m3pare
    679
    1,818
    SoCal (626)
    What’s it at right now? As long as it isn’t absurd like -4+, you’ll be fine. It’s bad toe that kills tires, -1 — -2 camber is ok on your tires.
  11. PutPutMobile
    292
    518
    Buena Park, CA
    The angle LR is -1 and RR is -1.6.... Toe is LR 0.2 and RR -0.3... this was last year in April. I’ll get it aligned again soon this month again.
  12. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    U def need them. 25mm
  13. PutPutMobile
    292
    518
    Buena Park, CA
    You think 25mm is too much? Or 15mm is ok?
  14. Nopho4u
    1,007
    2,061
    Socal son
    i had 17x8 +32. it only comes out 3mm more then my old set up w/ a 25mm spacer.
    my current wheels come out 32mm more then ur current set up.
  15. PutPutMobile
    292
    518
    Buena Park, CA
    I see. I’m gonna look for one soon before alignment again.
