For Sale Spacers, Spacers, Spacers, ..3 sets
Discussion in 'Private Sales' started by SubCode, Sep 24, 2016.
  1. SubCode
    SubCode Senior Member
    739
    1,341
    All 15mm, all hubcentric, 4 have attached studs , 2 are just plain...see pic....studed spacers $25m non studded 10, PM me for details..[​IMG]
  2. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    @SubCode I'll take the 4 with studs. Unless you'll let me buy just 2 for the rear of my car.
    torparts likes this.
  3. torparts
    torparts Senior Member
    417
    643
    Compton
    I'll take a pair of studded ones so I can split with inspector gadget
    Lmk thanks
  4. SubCode
    739
    1,341
    ok....thats fine...now pp [email protected]
  5. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    with the 15mm spacers you have to cut the original studs, right?
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That all depends on the wheel u have. Some have empty cavities where the lugs sit in.....in my case my wheels didn't have these cavities hence I had to cut mine.
    iPhone ?
  7. StarCaller
    1,284
    733
    ne idea if it will fit the 15" stock wheels without cutting?
  8. InspectorGadget
    216
    450
    Heber City, Utah
    @SubCode - Can I run the 15mm spacers with my OEM 17" wheels without cutting the studs? If yes, I'll send payment now that I'm back in town. If not, I apologize for wasting your time.
  9. SubCode
    739
    1,341
    The spacers already have studs....and I did not have to cut my studs...I just had a stud replaced last week...it's an easy mod to replace the stud...especially after seeing it done...1.remove the wheel 2. Loosen and remove the brake ..3 hammer out the old 4.hammer new stud in...5. Replace brake then wheel...
    But Rich I used these spacers on every modded car..I've own..
    And they work well with the stock wheels.
    #9 SubCode, Oct 3, 2016
  10. StarCaller
    1,284
    733
    17s or 15s ?
  11. StarCaller
    1,284
    733
    double post..../
  12. SubCode
    739
    1,341
    I was using them with 17's...
  13. StarCaller
    1,284
    733
    I just checked, there's no room for the uncut studs with 15s //
