Spare key fob
Discussion in 'Gen 3 Prius Main Forum' started by PriusOwner428, Aug 12, 2025.
  1. PriusOwner428
    PriusOwner428 Junior Member
    85
    IL
    2010 Prius. Bought used with only 1 key fob. Want to add a spare key fob. In the past was able to buy a key fob off eBay for a 2008 Prius and program it by doing the chicken dance (process of pushing various buttons and opening and closing door in a specific sequence). Can 2010 Prius key fobs be programmed this way as well, or do 2010 require a visit to the dealer?
  2. JC91006
    16,939
    8,647
    Making a new key for a 2010 requires a simple scanner with the key program function (Techstream or similar). No chicken dance. You can probably look up local locksmiths, they may do it for less than a dealership.
  3. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    PriusOwner428 likes this.
  4. Tideland Prius
    16,683
    @Tombukt2, should I be worried that unsavouries would see this post and replicate it?
  5. PriusOwner428
    85
    IL
    Thanks. Since there is no slot to stick the key fob in I figured the chicken dance was no longer an option.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    I bought a OBDII Techstream cable years ago for $25 off of Amazon.
    It came with free cloned software.
    It b was easy to add an additional key, but it had to be new and never previously programmed.
    You should not have it connected to the internet, since it will require that you sign on to Toyota's master computer.
  7. PriusOwner428
    85
    IL
    Has anybody used or is aware of ProKeyBox? Came across it while searching for solutions & seems like a good option if it's legit & not a scam. Thanks.
  8. Tideland Prius
    16,683
    Hearing no response, I will delete the post regarding reprogramming a key with off-the-shelf software.
