Spare Tire
Discussion in 'Gen 2 Prius Main Forum' started by TxAggie94, Jul 26, 2016.
  1. TxAggie94
    TxAggie94 Junior Member
    I need a new tire for my spare. It currently has a T125/70D16. This seems to be a fairly odd size and I cannot find one locally. I can get one ordered, but the starting price is nearly $200. I am thinking of going with a 125/80D16, which I can get for about 1/3 the cost, delivered. Anyone see a downside, other than potentially not fitting in the spare tire well. The 80 will be about 1” larger diameter than my current spare. I think it will fit, but will be tight. Anyone try this?
    As far as matching the other tires, this actually makes it closer to the diameter of the tires on the ground (24.5” outside diameter, vs. 24” for the 80 vs 23” for the 70).
    Thanks
    49,519
    tirerack.com?
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Junk yard for a complete spare wheel/tire assembly.
  4. TxAggie94
    Thanks...
    TireRack is where I get the $200 cheapest option I can find...$170 + $12 shipping + $15 to have it mounted locally.
    I've tried the closest Pick-n-Pull and one other salvage yard over here close to work with no luck. My mechanic out where we live called around there and had no luck. I think now I understand why they are so popular from the junk yards.
  5. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    Craigslist ? Sometimes folks part them out.
  6. bisco
    49,519
    i'm not familiar with those spec numbers, is it 16"? is this not a prius spec tyre?
  7. Dragon Rider
    Dragon Rider Active Member
    344
    211
    Miami
    bisco is correct. I got my from tirerack.com. full size tire will price was 143.00 shipping 179.00 but it will come to my house. Which is great .I am going to look at the 17 rims..
  8. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    IIRC from the last time I looked in my spare wheel well, there's at least an extra inch around the tire, so from memory I think a 125/80D16 would fit. I'd take a tape measure and just double check that there's enough space. It's actually possible to fit a full-size spare there, but you have to deflate the tire and carry around a decently powerful tire pump with you to do so: How to Install a Full Size Spare | PriusChat
    So long as it fits in the car, there's no disadvantage I can see, in fact the tire should handle slightly better as it's closer to the stock tires
  9. bisco
    49,519
    are we talking about the spacesaver donut?
  10. TxAggie94
    Yes, I'm talking about the donut, which is a 16" rim in my '06.
  11. bisco
    49,519
    does the car have 17's?
  12. TxAggie94
    No, the car has 15" rims with 185/65R15 tires.
  13. bisco
    49,519
    why would the donut have a larger rim, can i measure mine?
  14. bisco
    49,519
    my donut tyre says: T13580D16.
  15. bisco
    49,519
    blains farm and fleet shows a yoko in your size for 60 bucks.
  16. TxAggie94
    thank you!!! That's the one.
    I'd never heard of Blains...would have never found that.
  17. bisco
    49,519
    hope it works out, all the best!(y)
