"Spare" your thoughts...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by -1-, Apr 3, 2013.
  1. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :sick:Most owners are dismayed with Toyota's no spare tire decision for the PIP. Some owners have a year plus of ownership. Anyone willing to share a real life experience. I would assume they're rare. In my forty year driving experience, I can only recall two instances when I had a flat while driving. Both were caused by debris in the road.
    Gaudete likes this.
  2. Gaudete
    Gaudete Junior Member
    71
    Great new post! Thank you! I've been driving for 20+ years and never had an emergency flat that required a spare. That said, I was told (by the dealership) that the Prius's wheels are particularly delicate. Would love to hear if that's really true.
    -1- likes this.
  3. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    My most recent flat tire was in 2005 on my 1949 Ford running on 20 year-old tires. That was sure dumb (they had almost new tread). Before that, around 1995, on a driveway to a house in the woods a sharp stick made a large hole in a tire on my Toyota pickup. No gooey stuff and a pump would have fixed that. I have a 2010 Prius "doughnut" spare on a shelf. It goes in the back of my Prius Plug-in when we go out of the local metro area.
  4. Francos
    Francos Member
    118
    without the spare, the roadside assistance program is a must for me.
  5. CaliforniaBear
    1,180
    289
    Northern California
    I hope your cell phone has really good coverage :)
    Hi Burrito! likes this.
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Been driving for 15 years and have had 5 or so flat tires. I drive a whole lot though. I used to be a courier. A spare is a must for me. That goo will just be more complications and cost for me the next day.
    Granted I've only had one flat the last 5 years when I started driving late model cars rather than clunkers.
    DadofHedgehog likes this.
  7. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
  8. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I recently had a flat with my 2004 Prius due to a pothole at speed (the tire was not repairable - goop would not have worked. It was later replaced for free as a road hazard failure). The doughnut spare went on, but lasted only a 1/4 mile when it and the rim were destroyed by another pot hole (NJ is a dangerous place to drive). You need a full-size spare as AAA may not be able to get you going again otherwise. I had to find and buy a replacement tire (now a spare) late on a Sunday afternoon!
    JeffD
  9. CaliforniaBear
    1,180
    289
    Northern California
    Why won't the doughnut spare work, at least for reasonable roads?
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    How often have I had a flat in 20+ years, I recall 3 that left me stranded. Gains for consumers, weight reduction, possibly better MPG, and space? For car makers cost reduction? With TPMS these days, at least you know when you have a flat?
    A lot of automakers are going that way. I don't own a Plug In but considered removing my spare to reduce weight.
    markabele likes this.
  11. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There are other issues as well. My wife used the doughnut on her Subaru, This resulted in a $1000 repair to the AWD transfer case. A limited slip differential would also be damaged by a continuous difference in rotational rate caused by dissimilar tire circumference.
    The issue I had with the Prius is that the doughnut rim is very soft metal and was bent by a small bump in the road. The doughnut's narrow side walls do not provide much protection from road irregularities. You are much better off with a full size spare.
    JeffD
  12. Mendel Leisk
    42,385
    When they include a spare I'll consider buying one.
  13. CaliforniaBear
    1,180
    289
    Northern California
    I wonder how those thousands of non-plug-in Prius have managed to deal with the problems of the doughnut spare? That type of spare tire has been included since the first Prius was sold years ago.
  14. Sfcyclist
    1,621
    376
    SF, CA
    AWD system is quite different than Prius.
    Also, this is a spare to get to service station and that's it. I've seen idiots driving over 75 mph with these on!
  15. fuzzy1
    10,724
    Having almost that much driving experience myself, I think that is an indication of age-related fading memory, not lack of flat tires. :)
    I know plenty of places where no cell phone yet has coverage. I've been driving in them since before cell phones were invented, and am not ready to quit going there.
    CaliforniaBear likes this.
  16. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Luckily tire failures are relatively rare. I have only had one in over 60 years of driving. Had I had a full size spare, it would have been a non-event. Flats happen more often. These days usually slow leaks due to a nail or screw which can be temporarily handled by an air compressor (which I carry in my car as part of a jumper battery).
    JeffD
  17. Sfcyclist
    1,621
    376
    SF, CA
    very
    good point, most of my tire issues have been slow puncture leaks. With the TPMS that should alert me in advance to avoid tire failure caused by the small puncture.
  18. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I stated in my original post,
    "In my forty year driving experience, I can only recall two instances when I had a flat while driving. Both were caused by debris in the road." That was while driving. I've had other instances where I realized a tire was low on air with a nail, etc. while parked.
  19. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Like others I haven't had a flat for at least 15 years.
    I got the PIP March 2012 and didn't have a problem not having a Spare since I had Toyota Care.
    Then in June I had a flat. DAMN.
    Toyota sent a flatbed and the dealer fixed it for $25.
    I was without the car for 10 hours.
    Then 4 weeks later the same tire was flat again.
    This time I was able to drive it to the Dealer and they fixed it for another $25 since they found another screw in the tire. Either I had some BAD LUCK or it's an enemy of Green Technology !!!
    No problems since then.
    I would NEVER use the Sealant.
  20. kkitzhaber
    kkitzhaber Member
    Owen, WI
    Been driving 20 years. 5 years ago, I had a flat tire one hour east of Bismarck, ND, in my Oldsmobile. The sidewall was cracked, defective, ergo, no fix-a-flat could have saved me. So, I put on my spare and slowly drove 3 hours to the next town with a Walmart and got an in-warranty replacement (free of charge). Had there been no spare, I would have been stranded for hours, perhaps overnight. Yesterday, I bought a spare tire for my PIP on eBay, $75 ($40 of that is shipping). -- Updated: The spare that was sent is the wrong size. Got my money back and they said 'keep the spare.' It costs more to ship than its worth.
