Spark Knock (Detonation)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eman08, Apr 26, 2017.
Tags:
  1. eman08
    eman08 Active Member
    360
    192
    US
    Everyone
    I just discovered a new issue with my 09 Prius. I notice while accelerating or going up hill, my engine makes a spark knock notice. It makes that rattle noise when you put load on the engine. Is this pretty common on high mileage Priuses? I got currently 173,199 miles on this thing. Runs like a clock. I've yet changed the spark plugs but will be doing that later this summer. I'm going to go through a check list to fix this problem. Any idea if these engines have a knock sensor or an EGR Value? I have no CEL. I'm thinking of getting some seafoam. Perhaps my timing could be off.
  2. JC91006
    16,930
    8,639
    You can try putting higher octane gas and see if it'll go away. If not, you just probably have a worn engine with 173k miles on it.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    waiting to change the plugs will result in more engine damage, there is an egr valve. you can find many youtube videos on how to change it...plugs and valve will cost about 35 bucks, seafoam is a scam just do the needed tune up.. odds are you are low on oil too.
  4. eman08
    360
    192
    US
    Speaking of not changing my spark plugs.
    I have full service records from Toyota owners website, doesn't look like these spark plugs were ever changed since the car was made. I'm not even sure if the Transaxel fluid was ever changed either since the records all show the following I listed. I'm the 2nd owner. Looks like I'm well over due for both spark plug and Tranny fluid change. I imagine how dark the tranny fluid is. I heard about that these trannys are sealed lifetime fluid but sounds like baloney to me.
    VEHICLE INSPECTION INCLUDING
    CHECK ALL EXTERIOR LIGHTS,
    ENGINE COOLANT STRENGTH &
    CONDITION,ENGINE AIR FILTER
    ELEMENT, DRIVE BELTS, INSPECT
    ALL FLUIDS CONDITION & LEVEL
    ~|~REQUIRED MAINTENANCE
    ~|~PERFORMED WILSON TOYOTA
    MULTI-POINT INSPECTION
    50000 MILE MAINTENANCE
    INCLUDING TOP OFF FLUIDS & AIR
    TIRES TO SPECIFICATIONS
    and so on etc.
    #4 eman08, Apr 26, 2017
  5. JC91006
    16,930
    8,639
    spark plugs on a gen 2 takes 15 minutes. Easy to DIY
  6. eman08
    360
    192
    US
    I'm going to start off doing a compression test when I do change the spark plugs, that way I'll now if the engine is worn out or not. Then progress doing a fuel system cleaning.
  7. eman08
    360
    192
    US
    After I changed the spark plugs and dropped some Techron in the tank, with 87 octane fuel, the pinging has went away. It was just carbon build up due to racked up miles on this thing in a short amount of time. Spark plugs were brunt up like mad. Lol 1494355139053.jpg
    MJKae likes this.
