Spark Plug and Ignition Coil Install
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paphillyman, Sep 28, 2023.
  1. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    I have 2012 Prius 3 and figured it might be a good idea to put new spark plugs in with new Ignition Coil . I have about 66,400 miles on it but since its going on 12 yrs old I figured I better do this install. My question is : should you use dielectric grease when installing them and if so , where exactly does the dielectric grease go .
    Also I'll be using NGK (4912) ILKAR7BII Laser Iridium spark Plugs and
    Denso Direct Ignition Coil OE Quality-673-1310
    spark plugs is what Nuts About Bolts posted he used on Spark Plug Video on YouTube
    Just checking if I'm using the right material , Thank You
  2. Mendel Leisk
    42,240
    Toyota USA says 12 years or 120k miles for the plugs. My 2 cents, use the specd Denso SC16HR11 (revised by Toyota from Owners Manual), leave the coils, and don’t use any grease. Torque is 15 lb/ft with clean/dry threads.
    52,754
    what happens to low mile spark plugs after 12 years?
    have you cleaned the egr circuit?
  4. Mendel Leisk
    42,240
    I did mine at 12 years, and about 97K kms. They looked very similar to the new ones...
  5. bisco
    52,754
    good way to sell parts though
  6. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    I'm not having any troubles at all , and yes I have cleaned the EGR cooler and intake manifold and throttle body , plus installed a catch can ,just heard 120,000 miles or 12 yrs and I have a 2012
  7. bisco
    52,754
    me too. if it wasn't so much work, i'd take a look at them. i'm at 87k
  8. Mendel Leisk
    42,240
    In California it’s 15 years or 150k miles? :confused:
  9. bisco
    52,754
    LOL, they must get better plugs :cool:
