Spark plug broke off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CharlesPrius, Jun 2, 2019.
  1. Mendel Leisk
    42,352
    Well, he tried to to torque to 200 ft/lbs, but somewhere around 40~50 it snapped. :)
    A couple of times now, I've read here about folks misreading the inch/pound torque rating for the coil hold-down bolt, taking it as foot/pounds, and: you guessed it...
    When someone is hauling out a 1/2" drive torque wrench, tensioning it up, preparing to install this wee M6 locator bolt, you'd think they'd have a sober second thought?
    CR94, jerrymildred and WilDavis like this.
  2. CharlesPrius
    CharlesPrius Member
    154
    60
    Man I wish I did. Single dad here, things to do. I wish a screw type Extractor were possible here, but the broken-off wire and ceramic insulator are still attached. Not gonna try to break up the porcelain with an ice pick as I’ve seen one guy do in YT. My last gasp before shop opens Monday is to gently and very gradually try to grasp the remaining metal sleeve/washer end which is still present in the tube (see pic) with a yet to be purchased Extractor Socket. PBlaster should worked overnight I hope. Gonna spray it lightly again now and try this this afternoon. If it unseizes I’ll then vacuum anything loose before pulling completely. Gotta go to kid’s softball game now.
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I helped out a friend who had this exact scenario.
    Break up the ceramic (falls onto the top of the piston that you dont want to be at the top of its stroke), use a quality extractor to remove the spark plug barrel remnant , thoroughly vacuum up the ceramic and verify cleanliness with an inspection camera.
    Robert Holt likes this.
  4. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Ouch, I am not very optimistic on this one. The good news is that it will come off once the head has been removed.
    So you aren't hopeless. (y)
    Let us know please
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Get a small attachment kit for shop-vacs.
    Vacuum Micro Attachment Kit Mini Tools for All Vacuums - Walmart.com
    Use it to get the ceramic out of the center, since it should loose. Hopefully, the ground is the only thing keeping it from falling into the cylinder. Then it's just a matter of getting the easy-out into it.
    Sounds simple, but we all know it's going to be a PITA....
  6. CharlesPrius
    CharlesPrius Member
    154
    60
    Knowing little about how spark plugs are constructed, this may be ignorance. But from examining an intact plug & researching, if the ceramic (white) sleeve was going to fall any further downward, it seems it would have done so already -- especially since I had been poking around in there when I still thought the hex nut was present (it wasn't -- it had fallen to the ground when I initially broke the plug and pulled it out), and I can still see the white porcelain/Ceramic. I don't know what affixes the Ceramic to the Metal Case (glue?), but... Can any harm be done trying to grasp the remaining cylindrical Metal Case / Shell (the part just below where the hex nut was) with an Extractor Socket (similar to pictured)??
  7. CharlesPrius
    CharlesPrius Member
    154
    60
    Cost to remove head? I assume $1k, in which case, bye bye Prius
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    id foot the bill to the dealer that broke it and have them provide a rental while its being worked on on their tab also
  9. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    @CharlesPrius I like your chances. If that tool includes the right size to grab the ring where the fracture occurred, it is likely to pull it inward slightly, and that torsional bias shrink might be just the thing to free up the thread. Tough to say if one of those has the right size to grab inside and the right outer size to clear the tube going in.
    That's where the Lisle kit for the Ford looks attractive- the plug bore is the axis for all work done. I have not been able to figure out if the typical plug for a Ford Triton 12-valve engine is sized anything like the plug for the Prius. I would work on that if I were you.
    Have you run the car? I've always believed in pulling plugs from a hot aluminum engine and installing them in a cold one. Food for thought.
    Robert Holt and The Critic like this.
  10. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This should not require a machine shop. A competent mechanic can remove a broken spark plug.
    CharlesPrius likes this.
  11. iskoos
    415
    254
    Orlando, FL
    What dealer? He broke it while removing it. If this was done at the dealer, we wouldn't be having this conversation now.
  12. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    @CharlesPrius Since you have not done this before I suggest you follow the recommendation given earlier by someone who knows how. The easy-out method works well but probably NOT something you want to learn "on your own" in this situation.
  13. CharlesPrius
    CharlesPrius Member
    154
    60
    Correct; although I'm pretty sure the last plug job was done at a Toyota dealer, the time I'd spend trying to get them to cover anything isn't worth it. Pretty sure it was overtorqued because of where it broke (or the ceramic already was cracked when I grabbed the nut) -- but yeah, no dice.
  14. CharlesPrius
    CharlesPrius Member
    154
    60
    Yeah, I have free AAA tow and will be seeing my mechanic tomorrow. I'll suggest they try to pull the ceramic and center-electrode then easy-out it, though I'll take their advice, been a customer for years & they are trustworthy.
  15. CharlesPrius
    CharlesPrius Member
    154
    60
    I'm really hoping so! Towing it to mine in the morning!
  16. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    You would never be able to prove they broke it, even if they did. The last plug job was likely at least 75K miles ago and who knows how many hands have touched the car since then.
  17. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    My advice would be to not tell the mechanic how to fix it, since the reason you are taking the car to him is that you can't fix it. A dozen doughnuts for the shop always goes a long way to get a good job done.
  18. CharlesPrius
    CharlesPrius Member
    154
    60
    As you and I suspected, the Extractor Sockets I bought - the sizes that MAY grab hold of the plug's cylindrical casing - won't even fit into the plug tube, and I don't foresee there's a brand out there that will. So, taking it in tomorrow, hope they can do it.
  19. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I didn't realize how high up the plug broke. I thought it broke at the threads. If this had happened to me, I could see myself trying a few things. I have so many extra sockets laying around, I would probably just use one of the old plugs to size up an impact socket or heavy wall socket that's just slightly smaller and hammer that son of a gun onto the broken plug ring and then try to unscrew it. Go or blow...
  20. CharlesPrius
    CharlesPrius Member
    154
    60
    THAT is a great idea, though i also always tip the specific worker who does/did my job
    Yeah, wish you were around here... i'm handy but not that handy... plus i'm afraid of breaking off more of the ceramic, or the whole remainder, and have it fall into the cylinder. my mechanic hopefully has an answer
