Spark plug broke off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CharlesPrius, Jun 2, 2019.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    According to your signature you had a HG job done at 170k? New plugs would have been installed at that point....I would think?
    Where are you in CA?
  2. CharlesPrius
    CharlesPrius Member
    154
    60
    No, my mechanic only does what you ask for, and nothing more, and i didn't think of it at the time what with a $1600 bill for that one already
    The Critic likes this.
  3. CharlesPrius
    CharlesPrius Member
    154
    60
    FIXED! My mechanic's guys got it out from above! $100 & about 20 minutes (far above their normal labor rate, but I was happy to pay it). I didn't ask how - happily paid and left! Will keep an ear out for any related issues but it drove home just fine.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Good they got it out and the new one in. Those threads on the old plug look pretty rough - hopefully that happened after it was removed, perhaps when they were separating their removal tool from it.
  5. Mendel Leisk
    42,352
    Yeah looks like they had something that grabs/clamps on it.
    #45 Mendel Leisk, Jun 3, 2019
    CharlesPrius likes this.
  6. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    They drove an extractor into the inside of it, and unscrewed it from the cylinder head.
    Then they clamped the plug into a bench vise and did (UNPRINTABLE HORRORS) to remove the extractor tool from the plug shank.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    lol, did they mention where the ceramic went? Sounds like they did a good job, exactly as hoped and expected. (y) to them.
  8. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    Glad it was resolved without too much trouble ($).
  9. ETC(SS)
    7,564
    Best of luck for you in the future with the car, but HEY!!!
    I've been on PINS AND NEEDLES here because you forgot to answer the MOST important question!!!
    ...who won the softball game?
    CharlesPrius and kc5dlo like this.
  10. CharlesPrius
    CharlesPrius Member
    154
    60
    i didn't think about that... but yeah that seems to be the only way you'd get those dents on the exterior threads...
  11. CharlesPrius
    CharlesPrius Member
    154
    60
    They didn't, and I didn't ask, they just said "it's ready." I've driven it about 30 miles with no sounds or issues, though maybe the ceramic is on the highway somewhere...
  12. CharlesPrius
    CharlesPrius Member
    154
    60
    Yeah this is probably the last time I try even a moderately easy job like this... seems to go haywire plus i don't have a garage to work in or a backup car... Haha we don't keep score (rookie softball), but didn't play our best game... probably tied 15-15 haha
    kc5dlo likes this.
  13. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    First thought about the ceramic. It is pretty long even considering it is the bottom half, The length would help it from turning sideways enough to get past the electrode. Bits and pieces could get by but most if not all of the spark plugs I have broken were clean in two.
    Lots of time I feel certain I can tackle a "Simple" job only to be reminded when a problem arises that I am not a mechanic. Kuckily I have a very good friend next door that IS a mechanic.
  14. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    Just remembered an experience I had when I was about 17 with a Volkswagen. A sparkplug blew out while driving down the road. I was figuring on an expensive repair when I took it to a mechanic. I was called the next morning and told it was fixed for little to nothing. They drilled and Heli-tapped the threads. I asked if they took the head off ad he said they start the engine and drill it to keep the cuttings out of the cylinder.
  15. ChapmanF
    19,032
    He said they what?
    RMB likes this.
  16. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Usually they will start the engine with that plug out and hope to eject any bits of debris out the spark plug hole. There isn't much else you can do to clean the debris out short of pulling the head. Even bits of ceramic won’t hurt much - it is brittle and will crush into small pieces.
    #56 jb in NE, Jun 5, 2019
    Robert Holt likes this.
  17. ChapmanF
    19,032
    That sounds, at first blush, like one of the worst ideas I've heard in a lifetime of listenin'.
    Even snaking a vacuum hose in there sounds more promising.
  18. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The vacuum hose blocks part of the plug hole, limiting the size of a piece you can get out, in addition to the hose having to snake around to exactly contact any debris. The engine compression of about 10:1 generates a lot more “push” than a vacuum at 1 atmosphere generates “pull.”
  19. ChapmanF
    19,032
    Well, I would just use a magic vacuum hose that all the debris finds its own way to, same as the magic spark plug hole the debris all finds its way out of on the compression stroke (but never back into on the intake stroke).
  20. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Well, that’s how a lot of experienced mechanics do it. It must work for them.
