Spark Plugs Maintenance Schedule?
Discussion in 'Gen 2 Prius Main Forum' started by Organfreak, Dec 19, 2020.
  1. Organfreak
    Organfreak Junior Member
    48
    17
    Gig Harbor, WA
    Sorry, but I've been unable to find this specific information in any of these threads or in the owner's manual! There seems to be a standard of replacing the plugs after the first 120,000 miles, but my Prius II has gone 188K, and it is unclear from the service records whether the advice to replace them (at about 90K) was taken or not. I blame that on whomever wrote it up at the time.
    Context: my mileage has dropped from ~ 45 MPG to about 35 on a long highway trip. I repaired a leaky tire and then it went up to about 40 MPG. Tire pressure is perfect, oil change due in another 100 miles if I'm going by the 5K standard. One thread I read said don't replace plugs unless it runs badly. Any guidance on this?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I would be way more concerned about the health of the hybrid battery than the spark plugs. There all dying on the G2 platform from lack of driving. First sign of failing health Is poor mileage then purple bars real fast and slow and longer blue bar recovery then that turns into $$$$.
  4. Organfreak
    48
    17
    Gig Harbor, WA
    Oh, I AM far more concerned about that, but there's no lack of driving this one! I guess I'd better find out WTH purple bars mean. Don't believe I've seen them. Thanks!
  5. Organfreak
    48
    17
    Gig Harbor, WA
  6. PriusCamper
    PriusCamper Senior Member
    13,466
    5,433
    Pacific Northwest, USA
  7. Organfreak
    48
    17
    Gig Harbor, WA
    OK, now that I've studied-up on the colored bars' meaning it generates another question. I've never had any color bars other than green. Does that tell me that the traction battery is in good shape? :whistle:
  8. Mendel Leisk
    42,349
    You can download PDF format Owners Manual and Scheduled Maintenance Guide at Toyota Tech Info site, in the “Manuals” Tab.
    The scheduled change interval is in the second booklet, and the specd plug in Owners Manual.
  9. PriusCamper
    13,466
    5,433
  10. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    I'm not able to provide information on that. The first Prius I bought had the Denso's and I've never had the opportunity to try the NGKs. Sometimes it seems different cars just 'like' certain plugs. If I ever had one start acting weird, I wouldn't have a problem trying the NGKs to see if it liked them better. Maybe I'll buy a set to install anyway on the next family car that comes due. Mine has about 62k on the current set of Denso plugs.
    PriusCamper likes this.
  11. bisco
    52,858
    this should be so simple...
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    spark plugs do not cause bad mileage unless they have 300,000 miles on them .
    Majority of the cars power comes from the hybrid battery.
    All your seeing is green....no thats not true your just not paying attention but you will very soon when it starts getting old.
    Green does not last long but means the battery is very charged at least from the drivers perspective.
    Watch the battery behavior on the mfd. see how fast if it goes to purple bars and then how fast it recovers to one blue bar...then 2
    Failing battery packs are a real common post on this site.
    Sparkplus
    last change I used SK16s spark plugs lots of counterfeits out there I bought mine from Olathe Toyota on line. They run perfect.
    Already gapped don’t touch them.
    If your going to replace the plugs replace the valve cover gasket too and the PCs valve it’s all open then it’s easy just use some black gasket sealer on the front of the engine block to make sure it seals. Then When you take the v cover off use a box wrench on the PCs valve.
  13. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    It's likely in pretty decent shape. How quickly (or slowly) it goes up or down depends on how much capacity the hv battery has as well as how you drive the car. I refurbished the pack in my 2006 a few months back- it now measures at 5.5 Ah. I also drive 80 miles a day- mixed interstate cruise and local highway with moderate hills. I usually see the meter stay at 6 (blue) to 7 (green) bars- sometimes it hits 8. It can drop to 4 bars on extended uphill or stop and go driving.
    As long as they are genuine, both Denso and NGK are great spark plug brands that have been used as OEM by many car makers for decades.
  14. PriusCamper
    13,466
    5,433
    Why in the world would you want to change a valve cover gasket on a Prius? When I had a blown exhaust gasket cause a valve cover gasket to fail most auto parts stores said they couldn't get the part and that they never once seen someone order it.
    I mean I grew up in the 70's and 80's and understand why valve cover gasket replacement was considered expected maintenance on an old engine, but that was technology that's now 1/2 century old. There's no reason to replace this in a Prius as a preventative, only if it somehow gets damaged.
  15. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Well maybe if taking a few bolts off the valve cover and replacing that inexpensive gasket gets your nightgown in a bunch you should stay in the shallow end of the pool and concentrate on spark-plugs. But most people who have had only a cursory association with working on 4 bangers know the gasket weeping/failing at the spark plugs well is really common even on a well cared for motor.
  16. PriusCamper
    13,466
    5,433
    First I said I already did a valve cover gasket once, and it was alot more than the spark plug well that was the problem, but it was simple-easy. Second, if a bad valve cover gasket is "really common even on a well cared for motor" than how is that valve cover gaskets were so hard to find and auto parts store didn't have access to them and I was told multiple times that they've never heard of anyone ordering that for a Prius?
  17. Organfreak
    48
    17
    Gig Harbor, WA
    I have the manual, both hard copy and PDF, but don't have the the maintenance one.
    I don't like your tone. Should everyone here be an expert?
    alftoy likes this.
  18. Mendel Leisk
    42,349
    Again, you can download at Toyota Tech Info. Go to the Manuals Tab, enter your info and search:
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    was not directed at you it was directed to the guy that busts my chops all the time.
    You’ll know if it needs a gasket if you see oil on the plug when you remove the plug. I used my bore scope to checkout the plug well and saw some oil on my my really really well maintained car. Very common on this site for gasket to leak a little at the plug hole,
    You can use your iPhone to take a picture too just take a pic of the spark plug hole to see if any oil in the hole before pulling tithe plugl
    Very easy to take valve cover off and then very easy to take the PCv valve out too with the cover off that valve is due also.
    Seen many busted valve covers on here with people trying to remove that valve with the wrong wrench and knocking a hole in the cover.
    Gasket available at the dealer.
    #19 edthefox5, Dec 20, 2020
  20. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    ed,
    Step back and look at this again. The average person that is going to DIY a set of spark plugs (perhaps even for the first time) is in no way, shape or form, ready to be just casually popping off the valve cover to replace the gasket. Your post even talks about using rtv and how people commonly break the cover due to using the wrong wrench. Even if the cover had a minor seep, there's about a million ways this could make a nuisance problem into a significant problem.
    Hell, half the people here think you need to pull off the windshield cowl to swap plugs on a Gen2. The random guy trying to do the valve cover gasket will probably end up with leaks 10x worse than he started with.
    Many gen 2s in the 'extended' family. None have leaks in the spark plug wells, or anywhere else around the valve cover. All have original gaskets. This may not be as common of a problem as thought.
    alftoy and PriusCamper like this.
