Spark Plugs on 2012
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Superleaf444, Aug 5, 2020.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  2. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    (Maintenance Mode to make the engine run. PWR can make the engine run more easily while you're driving.)
    Looks like you're ready for this job. After the first time taking off the cowl, that becomes easy. The plugs themselves are a piece of cake. Just remember to "feel" them turning, and threading them correctly upon installation.
    Superleaf444 likes this.
  3. Superleaf444
    Superleaf444 Junior Member
    25
    Okay, I think this is my last question. Do you torque the plugs with the spark plug socket or do you only use that socket to get them in/out?
  4. Mendel Leisk
    42,264
    Spark plug socket. It's just a regular socket with rubber insert.
    I'd second the Denso plug mentioned in #14, why gamble.
    Tape the junction between extension and socket, to reduce risk of socket staying in the well after torquing.
    I'd avoid silicon on boots too, just makes a mess.
    Apart from the highish torque value, @NutzAboutBolts video is invaluable, for all the stuff you need to pull off.
  5. Superleaf444
    25
    Eck. I lied, one more question.
    I finally received my spark plug socket in the mail. No clue why one was so hard to find, probably COVID shortages.
    I was just about to start and watched the video again. anyway, the ignition coil bolts, are they supposed tightened to 8ft/lbs or 10ft?
    The nuts video says 10 by reads 8. And despite searching this forum, I can’t find anything. Another video I watched just tightened them by feel and didn’t even torque them.
  6. Mendel Leisk
    42,264
    Just snug them down. One-hand it with a ratchet wrench. They are small locator bolts, not torque critical. IIRC the torque value in repair Manual is in INCH pounds.
    At least two people here have misread and dogmatically torqued those in foot pounds, snapped the heads right off.
  7. ttou68
    ttou68 Active Member
    351
    211
    I agree with Mendel, but this might help...
    Torque specs:
    10 ft. lbs - Wiper arms
    6 ft. lbs - Wiper motor mount bolts
    9 ft. lbs - Cowl sub assembly bolts
    15 ft. Ibs - Spark plugs
    13 ft. lbs - Spark plugs with anti-sieze
    80 in. lbs - ignition coil bolts
    #27 ttou68, Aug 24, 2020
  8. Mendel Leisk
    42,264
    Dry thread torque for the spark plugs is indicated (in first attachement) as 15 foot pounds. That said, if you were to use anti-seize, 13 would be good I think.
    I wouldn't sweat torque values for anything but the spark plugs.
    Here's some repair manual excerpts:
  9. Superleaf444
    25
    Y’all are clutch. Omg. I did. Haha. F543B788-68FA-45A3-9D5E-0221C698A114.jpeg
  10. Superleaf444
    25
    Everything sounds fine? Lol. So hard to tell tbh. Basically I don’t hear anything massively different and it seems to run fine? I overthink things like this tho even when I’m doing things like cooking.
    bisco and Mendel Leisk like this.
